Gasket Part Number Help WD45
Jeff(WD45-SATX-TN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff(WD45-SATX-TN) Quote  Post ReplyReply Direct Link To This Post Topic: Gasket Part Number Help WD45
    Posted: 10 Feb 2012 at 1:59pm
I am trying to verify the correct part numbers for the seal and gasket to replace my belt pully. This would be the seal that goes into the clutch housing. The gasket is between the frame rail and housing. For a 1954 WD45
Are these correct?  70202289 For the belt pully tube to housing seal, 70223574 for the gasket between the frame rail and housing. Thanks in advance for the help. Jeff
1954 WD45 NF "Iron Tater"
Bill_MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill_MN Quote  Post ReplyReply Direct Link To This Post Posted: 10 Feb 2012 at 4:02pm
seal part is correct, not sure on the flange gasket
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff(WD45-SATX-TN) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2012 at 3:34pm
Bump - Anyone esle have input on the gasket between the frame rail and housing. The parts book has a note for 70223574 - seems for a WD only??
Bruce(IA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bruce(IA) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2012 at 3:58pm
I don't think it needs a gasket, only the round cork seal
The gasket was for the early, bolt-on covers
j.w.freck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote j.w.freck Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2012 at 8:23pm
there is no 3 eared gasket for thr phlange...just the cork seal
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2012 at 8:44pm
My WD has a round tin plug in that hole and 1 bolt/washer that catches the edge. Dad bought it new in 49 and that plugs been there as long as I can remember.I'm 56. I've never seen the belt pulley that's in the barn on this tractor.
David(Stockbridge)MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David(Stockbridge)MI Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2012 at 7:31am
Have them in stock......     www.djstractorparts.com David 734-320-3470
70202289
All "NEW" Web Site http://www.djstractorparts.com
2035,A,U,UC,WF unstyled,WF styled,WC High Crop (cane),RC,B,IB,C,CA,WD,WD45,G,D10,D12,D14,D15,D15 II,D17,D19,WC styled,WC unstyled H3 crawler
This page was generated in 0.085 seconds.
