Gasket Material-Alternative????
Chris/CT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Topic: Gasket Material-Alternative????
    Posted: 03 Apr 2010 at 8:06am
I need to make a .010-.012 thickness gasket for my Vickers Hdyro Unit, does anyone have any good materials they have used to substitute for this thin material, Thank-You.
scott View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote scott Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2010 at 8:26am
Cereal Box? Are you checking materials with a micrometer?
LouSWPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2010 at 8:37am
dad used to use dog food bags. I have no idea of thickness
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2010 at 8:46am
Sheet copper material.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2010 at 9:03am
Yes, Micrometer. Tis gasket is between charge pump and valve body, might make a difference if I used .032" which I have. Thanks for all the thoughts.C/CT
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2010 at 10:27am
My local fastener store, called Hokel has high quality gasket material in various materials by the square foot. I know the national seller McMaster-Carr has a wider selection. Some good car parts places and maybe Fastenal also carry sheets of gasket material that you can select by thickness and survival in the presence of oil or water or fuels (probably more than one variation for different fuels).
www.mcmaster.com likes to think its purely an industrial distributor so you have to make up a "company" name, but they take credit and debit cards and take orders on line or by phone and don't waste much of your long distance phone charge. But to do a good phone order you need to have a catalog and getting one of those takes ordering by the bushel each month or each week. Its all on line now too.
Gerald J.
Kevin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kevin Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2010 at 10:37am
try checking  NAPA or a Auto parts store.. The one here carries different thickness material by the sheet or by the roll..
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2010 at 6:52pm
I have some 0.022 copper. A 3'x8' sheet and a partial and a partial zinc coated. One square foot 16 oz.
Dusty
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2010 at 7:55pm
I use the mid -dollar silicon at the hardware store ; use the silicon gun and make a gasket; seems to work good,
BennyLumpkin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BennyLumpkin Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2010 at 8:04pm
Copper Seal is great stuff to use....that thing of a gasket you could probably apply the copper seal, let it start to set up a bit and install it....it would be stiff enough to not all smush out and put you pretty close.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2010 at 9:50pm
if it says .010 you better get a paper gasket about that size. this is a close tolerance pump. put it together with no gasket or RTV and it will lockup when yout tightne the bolts. Normal computer paper is about .003      , you need 2 layers of the heavy duty stuff or brown construction paper.  How about a brown paper bag from the grocery store?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2010 at 1:16am
IBM cards were .007" thick. Brown paper or IBM cards may not handle hot hydraulic oil at 3000 psi well though. I checked the Fastenal catalog a bit ago. No gasket material there.
The only .010 material at McMaster Carr is Gore tape, like 1/2" wide by 5' long catalog number 95705K21 for $32.75. Its rated at 3000 PSI and its mostly Teflon with fiber reinforcement. Might be an application where the manufacturer's product is the handiest solution, no matter what the cost.
Gerald J.
Dave H View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2010 at 7:03am
my thoughts were the same as Kevin's
