Gasket Material-Alternative???? |
Chris/CT
Joined: 11 Sep 2009 Location: Niantic, Ct Points: 1939 |
Topic: Gasket Material-Alternative????Posted: 03 Apr 2010 at 8:06am |
I need to make a .010-.012 thickness gasket for my Vickers Hdyro Unit, does anyone have any good materials they have used to substitute for this thin material, Thank-You.
scott
Joined: 12 Sep 2009 Location: michigan Points: 2769 |
Posted: 03 Apr 2010 at 8:26am |
Cereal Box? Are you checking materials with a micrometer?
LouSWPA
Joined: 11 Sep 2009 Location: Clinton, Pa Points: 25548 |
Posted: 03 Apr 2010 at 8:37am |
dad used to use dog food bags. I have no idea of thickness
Brian Jasper co. Ia
Posted: 03 Apr 2010 at 8:46am |
Sheet copper material. |
Chris/CT
Posted: 03 Apr 2010 at 9:03am |
Yes, Micrometer. Tis gasket is between charge pump and valve body, might make a difference if I used .032" which I have. Thanks for all the thoughts.C/CT
Gerald J.
Posted: 03 Apr 2010 at 10:27am |
My local fastener store, called Hokel has high quality gasket material in various materials by the square foot. I know the national seller McMaster-Carr has a wider selection. Some good car parts places and maybe Fastenal also carry sheets of gasket material that you can select by thickness and survival in the presence of oil or water or fuels (probably more than one variation for different fuels).
www.mcmaster.com likes to think its purely an industrial distributor so you have to make up a "company" name, but they take credit and debit cards and take orders on line or by phone and don't waste much of your long distance phone charge. But to do a good phone order you need to have a catalog and getting one of those takes ordering by the bushel each month or each week. Its all on line now too. Gerald J. |
Kevin
Posted: 03 Apr 2010 at 10:37am |
try checking NAPA or a Auto parts store.. The one here carries different thickness material by the sheet or by the roll..
Dusty MI
Joined: 13 Sep 2009 Location: Charlotte, Mi Points: 5061 |
Posted: 03 Apr 2010 at 6:52pm |
I have some 0.022 copper. A 3'x8' sheet and a partial and a partial zinc coated. One square foot 16 oz.
Dusty
DougG
Posted: 03 Apr 2010 at 7:55pm |
I use the mid -dollar silicon at the hardware store ; use the silicon gun and make a gasket; seems to work good,
BennyLumpkin
Joined: 22 Mar 2010 Location: Centre Hall, PA Points: 2657 |
Posted: 03 Apr 2010 at 8:04pm |
Copper Seal is great stuff to use....that thing of a gasket you could probably apply the copper seal, let it start to set up a bit and install it....it would be stiff enough to not all smush out and put you pretty close.
Joined: 11 Sep 2009 Location: illinois Points: 90833 |
Posted: 03 Apr 2010 at 9:50pm |
if it says .010 you better get a paper gasket about that size. this is a close tolerance pump. put it together with no gasket or RTV and it will lockup when yout tightne the bolts. Normal computer paper is about .003 , you need 2 layers of the heavy duty stuff or brown construction paper. How about a brown paper bag from the grocery store?
Gerald J.
Posted: 04 Apr 2010 at 1:16am |
IBM cards were .007" thick. Brown paper or IBM cards may not handle hot hydraulic oil at 3000 psi well though. I checked the Fastenal catalog a bit ago. No gasket material there.
The only .010 material at McMaster Carr is Gore tape, like 1/2" wide by 5' long catalog number 95705K21 for $32.75. Its rated at 3000 PSI and its mostly Teflon with fiber reinforcement. Might be an application where the manufacturer's product is the handiest solution, no matter what the cost. Gerald J. |
Dave H
Joined: 11 Sep 2009 Location: Central IL Points: 3607 |
Posted: 04 Apr 2010 at 7:03am |
my thoughts were the same as Kevin's
