Gasket adhesive |
ACinSC ![]() Orange Level ![]() Joined: 16 Dec 2015 Location: South Carolina Points: 3014 |
![]() ![]() ![]() ![]() ![]() Posted: 25 Nov 2019 at 2:44pm |
I used Indian Head shellac when I put the hydraulic oil pan on the D 15 . It didn't hold the gasket as well as I'd hoped . Maybe because it's old, I dunno . Just wondered what you fellas use ? Thanks
HudCo ![]() Orange Level ![]() ![]() Joined: 29 Jan 2013 Location: Plymouth Utah Points: 3922 |
brush on high tack [permatex brand] if i need glue one on a part before asssembly real sticky and sets fast,
MattLF9 ![]() Bronze Level ![]() Joined: 27 Nov 2009 Location: Minnesota Points: 187 |
CNH makes a gasket glue that works amazingly well.
I can't remember the name of it but the Case mechanics call it "calf snot" |
A little CQB never hurt anybody.
NomoreJohnDeere ![]() Silver Level ![]() ![]() Joined: 24 Jul 2017 Location: Missouri Ozarks Points: 308 |
was the surface clean?
HD3
200 10and20 ![]() Orange Level ![]() ![]() Joined: 20 Jun 2019 Location: Tim Buk Tu Points: 217 |
Get the best Copper Coat. Costs more but it's more than worth it. Make sure surface is clean and free of oil.
Yeah I'd cleaned the pan well and even wiped it off with alcohol . Thanks
DiyDave ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: Gambrills, MD Points: 54243 |
lay the pan on a piece of plywood, mark and drill all holes. then place gasket on plywood, and smear the top surface with blue goo. (blue silicone) Go lightly with the blue goo, you really don't want any squeeze out... place pan on top, and put all bolts through holes, to align. If you have longer bolts, to go through the pan and plywood, use them, and tighten them down till everything is flat. You really don't want to over torque these. If you don't have longer bolts, clamp the pan to the board, or weight down the pan. This way the gasket stays with the pan, to make assembly easier...
Dakota Dave ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: ND Points: 3971 |
Permeated aviation gasket cement
Thanks guys !!
DougG ![]() Orange Level ![]() Joined: 20 Sep 2009 Location: Mo Points: 8358 |
Copper Coats one of the least desirable,, Hi Tack is the good stuff,,
m16ty ![]() Orange Level ![]() Joined: 28 Jan 2011 Location: TN Points: 1476 |
I always Use Indian Head and have had zero problems when the directions are followed. You can't hardly get it back apart after it has set up.
As a side note they now call it "lion". I guess "Indian Head" was too politically incorrect.
Hi Tack is the best. Copper Coat works better for antiseze than it does for gasket sealer.
festus51 ![]() Orange Level Access ![]() Joined: 26 Mar 2017 Location: Osage City, KS Points: 1644 |
An fashion way to keep gasket in place with pan is to use string and tie the gasket in several places. When bolting it up place bolts and start them into block. Once you have several bolts in place cut string and pull out one at a time as start bolt in the string hole. This is an old mechanic trick from the 50's and 60's This is with an in frame overhaul.
Edited by festus51 - 25 Nov 2019 at 9:14pm |
We the unwilling Led by the unqualified Doing the impossible for the Ungrateful
Edited by 200 10and20 - 26 Nov 2019 at 4:29am |
DMiller ![]() Orange Level Access ![]() Joined: 14 Sep 2009 Location: Hermann, Mo Points: 34128 |
What many refer to as Calf Snot we also called Gorilla Snot in the truck industry, was a contact adhesive slight yellowish in color applied to both the gasket and the part to attach to. We used it on oil pan gaskets on the large engines to get them to Stay where we put them, almost took a grinder or sanding discs to get back off after a few months.
oldways ![]() Orange Level ![]() Joined: 25 Apr 2013 Location: west Ky Points: 509 |
I use Indian Head myself. Never have a problem unless it's really old. Gotta let it tack up a little before install. Lion is a different brand.
Yeah Lee , I think my Indian Head was just too old . I threw it away . I'll get a new bottle for next time . Thanks for all the replies .
NEVER green ![]() Orange Level Access ![]() Joined: 28 Feb 2013 Location: MN. Points: 8607 |
3M weather strip and gasket adhesive, love it. |
ocharry ![]() Silver Level ![]() Joined: 26 Jun 2016 Location: missouri Points: 288 |
permatex aviation ,,,,,never had a leak ,,,but its a pain to get off if you have to,,,,but it will take that over leaks,,,any day
ocharry
JayIN ![]() Orange Level ![]() ![]() Joined: 18 Dec 2009 Location: SE/IN Points: 1982 |
Boss Man ![]() Orange Level ![]() Joined: 03 Mar 2018 Location: Greenleaf, WI Points: 617 |
3M weather strip and gasket adhesive is what I use.
nickia ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: alden iowa Points: 792 |
3m weatherstrip adhesive for oil pan gaskets
and aluminum paint for the head gasket! |
