Gas Tank Holes
44 Allis B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 44 Allis B Quote  Post ReplyReply Direct Link To This Post Topic: Gas Tank Holes
    Posted: 20 Nov 2010 at 6:57pm
Putting a new wiring harness in the B today and noticed that the gas tank was really starting to leak on the bottom.  There is a place where it has been repaired in the past with an external application.  Looks like JB Weld.  I removed the tank and noticed that there are no soft pads on the lower support bracket.  A further inspection of the inside of the tank revealed allot of rust and a very bumpy corroded black surface.  I think it might be to my advantage to just replace the tank with another used one.  Just need to find one.  Anyone know where there is a good place to buy a used tank for a reasonable price?
1945 Allis B (B70687), 1953 Farmall Super M (F12856J), 1970 Farmall 826 Diesel (2510148U015442*) & 1969 Cub Cadet 106
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2010 at 7:07pm
If there are no local tractor salvage yards there are 3 different guys from WI who are constantly tearing down Allis tractors and putting parts on e-bay.
Rog(NCWI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rog(NCWI) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2010 at 7:17pm
I have a gas tank that has no strap on it .It would fit a 39 B. I live east of Wausau. Email me
Dave A View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave A Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2010 at 8:09pm
www.worthingtonagparts.com Worthington Ag Parts – Evansville, WI 1-800-525-7278
www.asapagparts.com Wis Tractor Parts – Black Creek, WI 877-530-2010
                                Wis Tractor Parts – Downing, WI 877-530-1010
www.annensmachineryranch.com - Windor, WI
www.caroline-implement.com - Caroline Implement, Marion,WI
Ed’s Tractor Repair, LLC – Berlin, WI 920-361-1262
Englert Enterprises – Sparta, WI 608-169-4871 or 1-800-648-9269
S & L Tractor Parts – Gillett, WI 920-855-2240
Mark Heitman Tractor Salvage – Durand, WI 715-673-4829
Edited by Dave A - 20 Nov 2010 at 8:10pm
Play the game for more than you can afford to lose... only then will you learn the game.
Winston Churchill
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave A Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2010 at 8:14pm
lakeside implament 608-296-2045 Harisvill.
Winston Churchill
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2010 at 9:41pm
How about fixing the existing tank?
I've used this on three tanks with great results.
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
Osage_Orange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Osage_Orange Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2010 at 9:58pm
I repaired a gas tank on a garden tractor with a fuel tank repair kit from the local auto parts store.  You could consider it temporary until a replacement tank is found........FWIW
Why is there never time to do it right the first time, but always time to go back and fix it?
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2010 at 10:07pm
Use blue coat, it will seal the leak plus coat the inside of the tank.    MACK
Brad MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brad MI Quote  Post ReplyReply Direct Link To This Post Posted: 20 Nov 2010 at 10:09pm
Empty and wash out tank real well to make sure there are no residual gasoline vapors. Clean the area to repair; a little blaster works best. Mix up some epoxy and apply to the area. Look over the interior of the tank too, it may need a tank sealer applied. Sand and paint it while it's off the tractor. DONE!
Edited by Brad MI - 20 Nov 2010 at 10:10pm
GlenninPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GlenninPA Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2010 at 9:29am
I taped up all the holes on a tank with black electrical tape (after cleaning like Brad said) and then used POR 15, like Stan said. After it cured, pulled off the tape and used JB Weld to fill in the pits and smoothed it out, Been 10 yrs, tank still holding like a champ.
