Gas Tank Cleaning?
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 15 Apr 2018 at 10:59pm
A little update...I rebuilt the carburetor today. It really wasn't bad looking, but I gave it a bath in carb cleaner anyway. Put it on the engine and rigged up a temporary little fuel tank. Started up and ran well after making a couple carb adjustments!
Next was the tank...I took a 10" length of chain and tied a wire on the end of it. Dropped the chain in the tank and proceeded to shake it around for a while, then moving the chain to the other half of the tank and repeating the process. After I was finished all kinds of rust powder came out! I couldn't believe it! Took an air hose and spent about 10 minutes blowing it out, and when I looked inside everything was pretty clean looking! Went ahead and put some "Ospho" in and shook it around to coat the inside. After draining and letting it dry, it seems most of the remaining rust was converted to the black iron phosphate, so hopefully, that will help the rust issue quite a bit. The chain really did get most of it out.
Hopefully next weekend I'll get the fuel valve installed and the tank back on the bike.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2018 at 5:13pm
Good luck Creston!  IF you happen to find a 66 or 67 Scrambler, let me know.  I'd bet one of my grandsons would like to have a ball on one....
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2018 at 10:55pm
do they work good in the snow Ted?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2018 at 12:30pm
Heck yes!!  But you better have a snowmobile suit on,,,the ground is kina hard.  You can do all kinds of stuff with a bike you can't do in a car or truck in that 'Pretty'.  WOOHOO
Creston, did you get that tank done yet?
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2018 at 3:48pm
Nope, I'm away from home for the week. Not sure if I'll be home for the weekend or not. School is getting pretty intense right now with semester reviews/finals approaching.
Luckily summer will be here before too long. Then I'll have more time to mess with it.
It's cleaned and ready to go, I just have to put it on the bike.
This page was generated in 0.176 seconds.
