gas shut off switch
Nat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nat Quote  Post ReplyReply Direct Link To This Post Topic: gas shut off switch
    Posted: 22 May 2011 at 12:02pm
 Does anyone know where I can find a 12V switch that will shut off the gas to the carb on my CA? I'm tired of having to shut it off at the settling bowl and if I don't a lot of time it will start leaking gas. If I had a switch that would shut the fuel off when I turn off the ignition it would sure be nice. Thanks, nat
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2011 at 12:08pm
Check with Grainger or a similar industrial supply house. You will need a normally closed solenoid valve rated for 12 volts and petroleum products. Personally I would keep using the manual valve - safer and a lot more reliable.
Boogerowen View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Boogerowen Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2011 at 12:18pm
Wouldn't it be cheaper and simpler to just put a new settling bowl on and have a new valve ? Also, have you tried tightning the packing nut on the one you have ???
Nat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nat Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2011 at 12:25pm
It's the carb that leaks and yes it's been rebuilt twice
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2011 at 12:41pm
I keep one in stock for my Industrial equipment customer's. Runs around $43. bucks. Have to add the postman also if interested...
Steve@B&B
Nat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nat Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2011 at 3:45pm
 How do they work and what kind of fittings does it have? will it do what I've got in mind?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2011 at 4:01pm
Maybe send your carb to Steve so it can be rebuilt right? They look and perform like new when he's done with them...
Bee View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bee Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2011 at 4:26pm
My 17.5 hp riding mower has one on the bottom of the float bowl.  Don't know how they are designed but this one failed in the open position.  The result-the cylinder filled with gas and hydro locked and bent a rod on startup.
Edited by Bee - 22 May 2011 at 4:28pm
Bob, North Carolina
1949 B
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2011 at 8:03pm
They seem to work fine. Pipe thread in each side.
Steve@B&B
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2011 at 9:16pm
Check with a LP gas business. They have them at a real good price.  MACK
