Gas Gauge Float Sealer
Michael (WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael (WI) Quote  Post ReplyReply Direct Link To This Post Topic: Gas Gauge Float Sealer
    Posted: 06 Feb 2012 at 6:15pm
The next project on my list is repairing some D-series gas gauges. I have some new corks ready to go but I am unsure what product was recommended in the past to seal up the cork so it won't get water logged by our savior, ethanol gas. I seem to think it was a liquid product called Seal All, but when I went to ACE Hardware all I found was a semi-solid product by that name in a tube.
Am I remembering the wrong name? What I use needs to be liquid so it can flow into the mounting hole in the middle of the cork.
Ryan Renko View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ryan Renko Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2012 at 6:54pm
Someone posted something about this before. They had a part# from a auto parts store that had a picture perfect replacement for the original cork one. I bought one and it works great. Maybe someone else can remember the store. It was made of plastic. Ryan
Chuck(ONT) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chuck(ONT) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2012 at 7:04pm
I wonder if a small plastic gas filter could be sealed and attached to the float rod. Just a thought.
Never take life too seriously.
Nobody gets out alive anyway!
1C 1 WD45 1 AC180
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2012 at 7:57pm
The replacement float was for a model A Ford. Pretty sure it was Charlie that found the float. Mine has a brass float soldered to the arm...
JoeM(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeM(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2012 at 8:12pm
I've always used this stuff on cork floats
Lowes and HomeDepot used to always have it
http://eclecticproducts.com/sealall.htm
Allis Express North Georgia
41 WC,48 UC Cane,7-G's,
Ford 345C TLB
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael (WI) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2012 at 8:43pm
First, thanks for the offers on the corks but I have those in hand already.
Joe, that is the product I found at ACE...if it is the consitency of silicone sealant like I think it is how do I get it to flow through the hole in the center of the cork float?  I guess I thought it was more of a liquid consistency.  The gauge I am fixing had a perfectly good cork on it, except it had sunk.
dustinmo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dustinmo Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2012 at 9:07pm
I got a bunch of corks a while back from a model T restoration place they were like 1.80 each and were already sealed, just to let you know , they are cheap and probally cheaper going this way than buying that sealer, they were the perfect size and work great, just look up model T or A gas gauge floats on the internet and you should be able to find them easy enough
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2012 at 9:25pm
Perfectly good corks don't sink. Only corks that NEED replaced sink.
You can throw away the cork float you have, buy 2 new neoprene floats that will never need sealing and have money left over. The sealer will cost the price of 2 neoprene floats and then you have the time involved messing with them. If you want "originality" pay a buck fifty for the sealed cork floats(model A Ford parts) and save even more money and your time.
 oldstandardautoparts.com has the neoprene float (which is resistant to ethanol) for about 4 bucks.
Edited by CTuckerNWIL - 06 Feb 2012 at 9:32pm
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2012 at 11:19pm
SealAll I what I have used and posted here. Its about the consistency of Duco cement. Its not like paint and I don't know what dissolves it. It won't flow, it will just allow itself to be smeared all over the cork and will probably plug both ends of the hole through the middle. It stands up to methanol, ethanol, and gasoline.
Gerald J.
Dave in il View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave in il Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2012 at 11:29pm
I just stop by the local garage and ask if the have any fuel pump/ sending units that they've replaced. They usually have some unless the trash was recently emptied and I can pull the float off for free. It's neoprene or some other plastic and will never need replaced and the price is right.
AGCO My Allis Gleaner Company
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael (WI) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2012 at 12:24am
CTucker, I must have missed the whole Model A Ford talk in the past.  I just did a search for a model A neoprene float and it looks like a pretty close fit.  I was not looking forward otherwise to trying to seal the cork floats I have.  I think I will give a neoprene float a try.  Thanks for the info.  Mike
David Maddux View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David Maddux Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2012 at 5:26am
I have used shellac on mine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2012 at 6:02am
 Call Kevin at Old Standard and ask for the neoprene gas tank float for the model A.
David(Stockbridge)MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David(Stockbridge)MI Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2012 at 6:07am
Have replacement floats in stock for D-Series, $10,, plus the ride. www.djstractorparts.com
All "NEW" Web Site http://www.djstractorparts.com
2035,A,U,UC,WF unstyled,WF styled,WC High Crop (cane),RC,B,IB,C,CA,WD,WD45,G,D10,D12,D14,D15,D15 II,D17,D19,WC styled,WC unstyled H3 crawler
Butch(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2012 at 7:19am
Maybe our fuel in Ohio is formulated differantly but I tried everything listed and more in an effort to keep the cork floats floating in my C6 Zeniths and none worked for more than a few months. This was with both the originals and the repros that used to be around. I could remove the floats and let them dry out for a week and they would again work for a few weeks before sinking, The fix only came when brass floats were adapted to the C6 float hinge.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2012 at 7:27am
Butch, Did you try the neoprene floats? They are supposed to be resistant to ethanol and I've never heard of anybody having trouble with them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2012 at 7:56am
Charlie I dont recall anyone having them for the C6. We are happy with brass Smile
JoeO(CMO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeO(CMO) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2012 at 2:08pm
Has anyone tried using Red Kote, the gas tank sealer?
D17JIM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote D17JIM Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2012 at 2:29pm
My fuel man gave me the rubber type float off of a broken tank gauge.  It's worked for 6 years in my gas D17.  Jim
