Gardens/Equipment? |
singingpig
Topic: Gardens/Equipment?Posted: 27 Jan 2011 at 8:51pm |
Matermacc. Works like a dream. |
MikeSMN
Joined: 11 Sep 2009 Location: Granada, MN Points: 122 |
Posted: 27 Jan 2011 at 8:08pm |
Mr. Singing Pig - what brand precision seeder do you have there?
singingpig
Posted: 27 Jan 2011 at 2:02pm |
Brad,
How come your soil is so white and cold looking? |
Brad VB
Joined: 11 Sep 2009 Location: Armour Sd Points: 149 |
Posted: 27 Jan 2011 at 1:39pm |
Here's a few pictures of my single row planter
singingpig
Posted: 27 Jan 2011 at 11:33am |
pallet of product ready to be loaded into the truck for delivery
singingpig
Posted: 27 Jan 2011 at 11:27am |
Walk behind, battery powered greens harvester for using with the high density seeder:
![]() A field of lettuce I harvested several times over a month, then let go to see. In this .2 acre there were 100,000s of lettuces with flower stalks 4 feet high...this is after just 1 pass with the Maschio tiller...now it is all worm food. ![]() Edited by singingpig - 27 Jan 2011 at 11:31am |
singingpig
Posted: 27 Jan 2011 at 11:22am |
7 foot wide Maschio B series tiller. Almost never gets used. As my soil has improved through proper management, chisel, disc and cultipacker gives a perfect seedbed in a fraction of the time using a fraction of the fuel. This thing is a beast, though. It gets most of its use grinding in cover crops and crop residue before chiseling or discing.
![]() Wind guage so I know how to set the irrigation: ![]() |
singingpig
Posted: 27 Jan 2011 at 11:14am |
23hp. 12 ft wide cultipacker ![]() 9 ft wide 3pt disc. My next purchase of equipment will be a 12 ft disc with a sprocket roller to pull behind the John Deere. Also, know where I can buy a heavy harrow/roller combo just up the road. Need to dig my self out of the hole before I buy any more equip, though. ![]() Edited by singingpig - 27 Jan 2011 at 11:18am |
singingpig
Posted: 27 Jan 2011 at 11:13am |
Steve, that is sweet looking. Here is my 1st ever tractor. A Case195. Used it when I was still farming 1.5 urban acres in PDX. Was perfect for getting right up to the wall in my greenhouses.
Edited by singingpig - 27 Jan 2011 at 2:00pm |
singingpig
Posted: 27 Jan 2011 at 11:10am |
Ford 5030 62hp 4WD tractor. I use it for seeding and spraying, discing, packing etc. Also use the loader for just about anything you can imagine. 2400lb capacity so unloading totes of feed is a breeze. Old 8 foot spring tooth harrow on the back
![]() Edited by singingpig - 27 Jan 2011 at 11:11am |
singingpig
Posted: 27 Jan 2011 at 11:05am |
4 row precision seeder. In this photo I am using it with the clod pushers down on the 2 outside rows to cut furrows for onion transplants. By using the seeder to cut furrows for my transplants, I know the row spacing is always proper for cultivating with the G
![]() Side view of seeder. Clod pushers in front, dual disc openers, V-wheel tampers. PTO turns vacuum pump which gives excellent singulation of seeds. I use it to seed everything from tiny herb seeds to winter squash. By changing seed plates, and the gear ratio it will seed at anywhere from 1.5 inch to 6 feet spacing in the rows. I usually set it to slightly overseed so 2-3 seeds drop instead of 1. ![]() |
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42104 |
Posted: 27 Jan 2011 at 11:02am |
Eldon : looks like rocks and houses grow good in your area also . How soon before them houses push you out from all that dust, noise, and complaints you don't get your food from the grocer where most people do .
R.W
Joined: 31 Dec 2010 Location: Swanton, OH Points: 2975 |
Posted: 27 Jan 2011 at 10:58am |
What is the hp rateing of that G diesel? |
singingpig
Posted: 27 Jan 2011 at 10:56am |
Nelson 200 series Big Gun, I water about 6 acres with this. I have 4 risers in a line E-W, just unclamp the gun, clamp on the plug, move to the next riser They are about 250ft apart giving a good overlap. Gun puts out a 220 foot radius if the wind isn't blowing lol. That's with a 1 inch nozzle, 350 gpm at 120 psi
![]() One of 2 , 880 foot long wheel lines. Waters about 1.5 acres/set. With both running, it doesn't take too long to get the watering done. ![]() Edited by singingpig - 27 Jan 2011 at 10:57am |
singingpig
Posted: 27 Jan 2011 at 10:48am |
1948 G with a new Kubota 23hp diesel, live hydraulics, 12vdc, instrument cluster and key start. Uses 1-2 gallons of fuel for 8 hours of cultivating
![]() Business end of the G cultivating asparagus in March ![]() |
singingpig
Posted: 27 Jan 2011 at 10:42am |
Primary tillage...JD5020 with a 9-shank chisel plow
![]() Required safety equipment: ![]() |
singingpig
Posted: 27 Jan 2011 at 10:39am |
High density seeder for salad greens...plants 20 rows in the same bed as my precision seeder plants 4 rows:
![]() Home made boom sprayer and 275 gal tank of hydrolyzed fish: Booms are 35 feet wide total, so I can foliar feed 7 growing beds in one pass ![]() |
CTuckerNWIL
Posted: 27 Jan 2011 at 8:46am |
1954 WD45 with power steering.
R.W
Posted: 27 Jan 2011 at 8:42am |
Charlie is that a wd or a wd45?
CTuckerNWIL
Posted: 27 Jan 2011 at 8:23am |
JohnThomas
Joined: 14 Sep 2009 Location: Traverse City Points: 332 |
Posted: 27 Jan 2011 at 4:48am |
Love those butternut squash! Wish mine would get that big!
I have a Seaman Tiller on my WD. How deep do you go with yours on the veggie gardens? How thick you spread the muck? I'm wondering if I go too deep sometimes. No clay here..black sandy loam....built up over the years with mulch......red sand below that. You sure have enuff equipment!!! |
Life is short...Make haste to be kind
Eldon (WA)
Joined: 11 Sep 2009 Location: Spokane, WA Points: 7765 |
Posted: 26 Jan 2011 at 8:19pm |
To start out I haul in manure with this
![]() Then spread it with this
![]() Then till it in with these
![]() ![]() Then plant with this
![]() and maybe this if I get a hitch made for it
![]() Cultivate with this
![]() ![]() and harvest with this...sometimes
ALLIS EXPRESS!
This year: |
Allen Dilg
Posted: 26 Jan 2011 at 7:59pm |
Hello R W We have a 60' x150' garden by the house, for vegatables, 20 fruit trees, and several BERRY patches. We also rent 3+ acres next door for sweet corn squash, and pumpkins. We use almost all AC equipment D17 to haul manure D15 to load it D19D to plow and a 1200 field cultivator, D10 with 2 row disk opener corn planter, Allis G for cultivation and herbiside sprayer, AC 5020 with 6'rototillerfor garden prep and 14" rear tine Sears tiller for rows. also 175 AC with 904 haybine and 444 baler with 4 restored Allis hay racks, with all lumber cut from USED TELEPHONE POLES.
SHAMELESS
Joined: 13 Sep 2009 Location: EAST NE Points: 29486 |
Posted: 26 Jan 2011 at 7:24pm |
oh yeah..forgot to mention, the planter,cultivator,harvester will be my ole lady....oooops...i mean my loving wife!!
SHAMELESS
Posted: 26 Jan 2011 at 7:23pm |
think we're gonna do the greenhouse gardening this year, gotta git it built yet, thinkin one about 30-40 ft long
Steve in NJ
Joined: 12 Sep 2009 Location: Andover, NJ Points: 12045 |
Posted: 26 Jan 2011 at 6:26pm |
I don't have a garden, but does a Garden Tractor quailfy in the equipment catagory? Boy, I've been havin' a ball plowing snow with this thing this year! This is the first year in a loooong time that I'm not minding the snow storms. And boy, we've been getting snow storms one right after another! Snowin' like crazy right now.... Steve@B&B
wjohn
Posted: 26 Jan 2011 at 6:23pm |
My family raises sustainably grown lettuce, radishes, cabbage, carrots, onions, tomatoes, okra etc. etc. Our hard clay is a challenge because crops frequently get drowned out in spring rains, but I'm hoping to do some ditching and bed shaping with a rotary plow. As I mentioned in the walk-behind post, we've got Gravely and BCS walkbehinds for gardening, and we also use several Earthway seeders to plant many crops.
I'm hoping to have my B ready to plow and cultivate corn for the summer after next. The WD mostly gets used for bush hogging and pulling out stuck vehicles... I'd love to plow with it, but the back rims are about shot.
HagerAC
Posted: 26 Jan 2011 at 3:54pm |
Here is our workhorse, its a 1948 G we used to till the ground, and do some cultivating as we have 2 large gardens. It is mostly used in the garden, and rarely goes to shows, but we do take it some.
R.W
Posted: 26 Jan 2011 at 3:22pm |
Yall gou any pics of your past gardens and your garden/produce equiptment?
I have a produce stand and i sell sweet corn, tomatoes, cucumbers, zuchenie, peppers, watermelons, and pumpkins. I also grow radisheses, brochily, greenbeans, and ockra for just us.My olny piece of equipment is a craftsman self propelled rear tined tiller a rake and a couple hoes. Im hopeing to get a 2 wheel tractor or a small tractor to cultivate with and some other equiptment for my own opperation in sted of using my dads stuff. you know when your a kid you want your own line of equiptment. Thats enough about my stuff how about yours?
