Garden Tractors |
Scott(SC) ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Starr, SC Points: 397 |
![]() ![]() ![]() ![]() ![]() Posted: 02 Dec 2010 at 6:56am |
I bought 3 garden tractors: a Sears Suburban, a Simplicity, and a David Bradley. All 3 have single cylinder cast iron B&S engines. Where can I find out info on these tractors and engines? Thanks, Scott.
omahagreg ![]() Orange Level Access ![]() Joined: 11 Sep 2009 Location: Omaha, Nebraska Points: 2806 |
Sears has online information on most of their stuff. Sears.com, I believe, then you will need numbers off of the machine to get specifics.
Greg Kroeker
1950 WD with wide front and Freeman trip loader |
john(MI) ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: SE MI Points: 9262 |
jaybmiller ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Greensville,Ont Points: 24658 |
For the engines, go to B&S site, ther's a link to where you enter in model,type and code and you'll get the engine's illustrated manual in PDF format. Once you save it, copy and rename it to something 'normal', B&S12hpVS.pdf.
By the way the 'code' is the year-month-day and shift when built (yrmtdy....). If the engine is original to the tractor, it's agreat way to figure out how old the unit is!
427435 ![]() Orange Level ![]() Joined: 18 Nov 2010 Location: SE Minnesota Points: 18637 |
Here are a couple of sites you should consider:
http://www.simpletractors.com/club2/forum.asp?FORUM_ID=7 http://www.mytractorforum.com/forumdisplay.php?f=16 |
Mark
B10 Allis, 917 Allis, 7116 Simplicity, 7790 Simplicity Diesel, GTH-L Simplicity Ignorance is curable-----stupidity is not. |
Jeff-in-Kunkletown ![]() Silver Level ![]() ![]() Joined: 13 Sep 2009 Location: Pennsylvania Points: 494 |
Davidbradley.net is a real good source of information. |
Sucess is how high you bounce after hitting bottom. Gen. George S. Patton
Check out www.asecc.com for old Briggs info. If they turn out to be model 23 engines I know I have several connecting rods and possibly a gasket set or 2.
