Garden Tractors
Message Reverse Sort Order
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Topic: Garden Tractors
    Posted: 02 Dec 2010 at 5:10pm
Check out www.asecc.com for old Briggs info. If they turn out to be model 23 engines I know I have several connecting rods and possibly a gasket set or 2.
Jeff-in-Kunkletown View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff-in-Kunkletown Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2010 at 12:34pm
Davidbradley.net is a real good source of information.
Sucess is how high you bounce after hitting bottom. Gen. George S. Patton
427435 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 427435 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2010 at 11:25am
Mark
B10 Allis, 917 Allis, 7116 Simplicity, 7790 Simplicity Diesel,
GTH-L Simplicity
Ignorance is curable-----stupidity is not.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2010 at 7:58am
For the engines, go to B&S site, ther's a link to where you enter in model,type and code and you'll get the engine's illustrated manual in PDF format. Once you save it, copy and rename it to something 'normal', B&S12hpVS.pdf.
By the way the 'code' is the year-month-day and shift  when built (yrmtdy....). If the engine is original to the tractor, it's agreat way to figure out how old the unit is!
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2010 at 7:18am
omahagreg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote omahagreg Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2010 at 6:58am
Sears has online information on most of their stuff.  Sears.com, I believe, then you will need numbers off of the machine to get specifics.
Greg Kroeker
Scott(SC) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Scott(SC) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2010 at 6:56am
I bought 3 garden tractors: a Sears Suburban, a Simplicity, and a David Bradley. All 3 have single cylinder cast iron B&S engines. Where can I find out info on these tractors and engines?   Thanks, Scott.
