G-262 engine
only AC orange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote only AC orange Quote  Post ReplyReply Direct Link To This Post Topic: G-262 engine
    Posted: 25 Jun 2024 at 7:58am
I have a G-262 engine for parts that needs to move on. Block, head, crankshaft, camshaft, manifold (2), water pump (2), oil pan, valve cover, combine governor, rods and pistons, all for $100.00. If no interest, going to scrap yard!
GleanerFMan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GleanerFMan Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2024 at 10:46am
If you still have it, I’m looking for a carb with all of the linkages that sit on the throttle shaft if you still have it?
Post Options Post Options   Thanks (0) Thanks(0)   Quote only AC orange Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2024 at 8:26am
I don't have a carb. or linkages, used them when replaced the tractor engine with combine engine. Do still have all the other parts.
Model 70 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Model 70 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2024 at 8:34am
I’d be interested in the oil pan and the water pumps if you want to sell separately
Post Options Post Options   Thanks (0) Thanks(0)   Quote GleanerFMan Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2024 at 9:40am
That’s fine, got something jerryrigged up so should work for harvest, thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote only AC orange Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2024 at 6:57pm
Oil pan and 2 water pumps are still available. Pan is OK - no rust or pin holes, water pumps turn freely - put a new pump on when putting combine engine in tractor. I'm in East Central In., don't know of anyone heading your direction? How about $100.00 for all not including shipping?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Model 70 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2024 at 8:54pm
That sounds fair   Unfortunately I don’t know of anyone coming to northern Mn so would have to ship
