G Valve Seat ?
Allis Barn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis Barn Quote  Post ReplyReply Direct Link To This Post Topic: G Valve Seat ?
    Posted: 01 Feb 2010 at 8:36pm
I have a 1949 model G that has a chuck of metal missing in the exhaust valve seat of the # 2 cylinder.  Compression on # 1, 3 & 4 cylindersis 95 psig.  30 psig on #2. Have talked with two machine shops I have used in the past for work on CE engines and both have a problem with machining the small diameter valve seat to install a valve seat insert.  They both say a 1 inch insert is the proper size to use, but neither can go below an insert of 1 1/8 inch.
Can I go with a 1 1/8 OD insert?  Are will this cut into the water channel?
Any other advise on how to repair a badly chipped valve seat?
Thanks Bob (VA)
Brett(Va) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brett(Va) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Feb 2010 at 9:53pm
 Bob,the G uses a Continental engine. Check out your local industrial engine supplier or a good small engine shop. I think 1" is the same as Kohler. Continental got bought out by Teledyne Wisconsin years back and they were bought by Fugi/Robin which later sold to Subaru I believe. Last I heard they liquidated most of the old stuff and kept Robin. I haven't kept up with dealers,but I'm sure as many Continental and Wisconsin industrial engines that are out there,that someone bought up the pieces.
What part of VA are you in. Maybe I can find a dealer in your area.
Brett
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis Barn Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2010 at 7:24am
Brett, I am just down the road from you in Waynesboro.  This G came from the Mrotek sale last year.  Just getting around to working on it.  It was a running tractor, but one cylinder had extremely low compression.
This is my first exposure to a G.  Most of my hobby has been directed to B, C and CA models.
As for the valve seat, I really need a machine shop that can machine a 1 inch recess in the block for anvalve seat insert.  My two "old reliable" shops can not do it unless I spring for a the machine tools to go that small ($100.00 plus)!   I am sure there is a shop out there, I just need to find it.
Appreciate the feed back.
Thanks
Bob (VA)
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2010 at 7:59am
That engine is a N-62 Continental.
Dusty
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brett(Va) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2010 at 8:00pm
 Bob, Give  KREIDER MACHINE SHOP INC. in Harrisonburg a call. I don,t have their number ,but they are on Mt. Clinton Pike on the NW side of town. They can help you.
Brett
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2010 at 7:02am
I have a G (N62) block in my home shop that needs a valve grind. I have not got around to start on it and it will be some time before I do.  I checked my valve seat cutters and the smallest cutter is 1 5/16.  It could easily be done smaller on a CNC. In the past I have made special valve seats on the lathe. This would not be [inexpensive] to order special steel to make a seat and set up on a CNC to cut the pocket. It would not be rocket science but would take a machinist's time and not many would have the pre hardened steel in stock.
The block is cast iron and if you could find a welder that would use a cast iron rod as filler the seat chip could be filled in and recut with standard seat cutters after it was decked.
This page was generated in 0.057 seconds.
