"G" surging
Dwayne TX View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dwayne TX Quote  Post ReplyReply Direct Link To This Post Topic: "G" surging
    Posted: 05 Dec 2010 at 3:27pm
My G revs up and down.  I can see the governor rod moving when it's doing it.  If I hold the rod, it idles normally.
I compared the rod to a couple of other G's and mine is two-piece with a clamp, while the other two are solid.
Do I need a new spring or does the rod need adjusting?
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2010 at 5:53pm
You have an adjustment screw that can be seen just below the spring linkage.
It is a surge damper adjustment. Bottom right of the picture with a jam/lock nut.
Give that a try.
JoeM(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeM(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2010 at 6:50pm
see if this helps
Edited by JoeM(GA) - 05 Dec 2010 at 6:57pm
Allis Express North Georgia
41 WC,48 UC Cane,7-G's,
Ford 345C TLB
This page was generated in 0.077 seconds.
