G starter dragging |
Thad in AR. ![]() Orange Level Access ![]() ![]() Joined: 12 Sep 2009 Location: Arkansas Points: 9668 |
![]() ![]() ![]() ![]() ![]() Posted: 29 Jan 2023 at 1:15pm |
I’m gonna have to get it rebuilt. It just turns too slow. I put on cheap jumper cables from a 12 bolt and it still wasn’t fast enough.
I undid the ignition wire and jumper Ed it to the 6 volt battery and then put a 12 volt battery to the starter and it starts but still doesn’t crank very fast. I pulled the starter and blew it out. It liooks nice and clean. I wire brushed where it bolts to the tractor and wire brushes the bell housing where it bolts up. I removed the battery box and cleaned and wire brushed the mounts and where it bolts up. Brand new battery and brand new cables. |
Alberta Phil ![]() Orange Level ![]() ![]() Joined: 13 Sep 2009 Location: Alberta, Canada Points: 3929 |
Send it over to Steve at B&B. He'll fix it up so it spins that 'G' right over!!
Steve in NJ ![]() Orange Level Access ![]() ![]() Joined: 12 Sep 2009 Location: Andover, NJ Points: 12007 |
Thad, sounds like that ole' girl needs an Armature in it. I can rebuild it for ya if interested. Thanks Phil for the Kudos! Steve@B&B
Steve I was hoping you’d see this. I have it up for sale and a couple guys very interested. I’ll have to explain the situation to them. Can you PM me a price and a guess on the shipping to North West Arkansas? I was concerned that parts may be hard to come by these days? |
Thad, sent ya a PM....
DSeries4 ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7511 |
Check the ring gear to make sure it isn't worn. With new gears on a rebuilt starter, a worn ring gear will wear down those starter gears pretty quick!
corbinstein ![]() Orange Level ![]() Joined: 31 Jul 2014 Location: Oklahoma Points: 796 |
You stated you put on new Cables. Reminder..... Those cables need to be as thick as Goucho's Cigar.
I also used different cables to run a 12 volt battery to it. It still turned slow. |
The teeth appeared good when I had the starter out. I even felt the back side to feel for any bad spots I couldn’t see. |
