G oil pump gasket
randy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote randy Quote  Post ReplyReply Direct Link To This Post Topic: G oil pump gasket
    Posted: 02 Feb 2017 at 8:42pm
I&T book calls one of the gaskets a, lead gasket, and my gasket set just has paper gaskets. AGCO parts doesnt mention a lead gasket. Did they discontinue the lead gasket?
Thanks Randy
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2017 at 8:56pm
Randy, I have fixed several, no lead gasket came with any of the kits. HTH Tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2017 at 5:54am
Lead is one of them 'bad' things...sigh... too many regultions concerning it, so it was 'time to get the lead out'......
The 'paper' ones will work fine.
I think lead was used as it was 'thick and soft' so would conform and fill any small voids or machine 'grooves'. If you 'polish' the mating surfaces real good,paper will be fine. If you really,really wanted to , you could add two gaskets made from soda cans, with paper in the middle, sandwich style...
Jay
Post Options Post Options   Thanks (0) Thanks(0)   Quote randy Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2017 at 6:57am
Thanks for the info. Paper it is.
This page was generated in 0.095 seconds.
