G No 5
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Topic: G No 5
    Posted: 07 Jan 2011 at 7:43pm
Bought my 5th G this evening. Only 5 miles from my place. It has a neat homebuilt blade with two way hydraulics for up/down and side to side tilt. Runs off the factory pump, also has the belt pulley drive. It has been converted to 12V and alternator, someone did a nice job modifying the rear shroud for it.
ALLIS EXPRESS!
This year:
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2011 at 8:26pm
Posting is gone already.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2011 at 8:33pm
I see.....I'll post some pics  tomorrow after I bring it home.
ALLIS EXPRESS!
This year:
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2011 at 12:37pm
Some pics.
ALLIS EXPRESS!
This year:
Chris/CT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2011 at 12:55pm
What was the previous use for this machine? Grading dirt/snow removal?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2011 at 1:15pm
The seller bought it back in '93 and built the blade for it.  This is the snow blade, he also had a serrated dirt blade and made a bracket that holds a  4' front blade (works opposite of the belly blade).  One bolt and the blade will come off, leaving a tool bar that can be tilted side to side.  I plan on making a set of cultivators like I already have and use them on the toolbar...I have times now when one side digs and the other doesn't, the tilt feature will solve that problem.  It also has down pressure, so I won't have to stand on the cultivator to get it to dig.
ALLIS EXPRESS!
This year:
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2011 at 1:59pm
Looks like a nice tractor, congrats on the new addition.
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2011 at 2:17pm
Ugh. 2000 to 3000 psi on 125 psi pipe fittings?
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2011 at 4:25pm
Gerald, I must have some good schedule 40 pipe fittings on my 45 cause when I had ny pump rebuilt with a new relief spool, it wasn't machined properly. I blew out a 5000 psi gauge testing it. When I put a 10,000 psi gauge on it, it final bypassed at over 9,000. I took it back apart and found the problem and repaired it. The relief spool came from AGCO and there was a 1/4 inch deep c'bore missing which made it work like you added a 1/4 inch of shim to the relief. She's runnin about 2800 now. My traction boost gauge don't work anymore now. It's kinda stuck 3/4 of the way up. Charlie
Edited by CTuckerNWIL - 08 Jan 2011 at 4:26pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2011 at 4:35pm
Gerald there is no pressure on those fittings...it is just the (dump) return line to the tranny.
ALLIS EXPRESS!
This year:
Jim Lindemood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim Lindemood Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2011 at 5:29pm
Really nice find --- cool set up.  Think you are "over G'd" --- need to drop one of 'em off at my barn, LOL
Steve-Ohio View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve-Ohio Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2011 at 10:15pm
Pretty neat Eldon, quite a setup.  Now I want to see you out in a blizzard pushing snow with that and not in one of your bigger AC's that have a cab.  LOL
Rick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2011 at 7:09am
Yeah,Steve,I was thinking the same thing! I think it'll work better for him as a cultivating tractor also,'cause he'd be burnin' that clutch out pushing as much snow as he gets out there! LOL!  Rick
This page was generated in 0.069 seconds.
