G lift thingy
Creek Jenkins View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Creek Jenkins Quote  Post ReplyReply Direct Link To This Post Topic: G lift thingy
    Posted: 11 Feb 2010 at 10:33am
Well I finally got a set of master tool carrier frames for my G.  Now I only need the pressure rod / rod spring / trunnion sets and I'll be able to use the cultivator this spring.
Anybody have any of these for sale?  Or has anyone built something to substitute for them?  They don't look real complicated.  I was thinking maybe they are used elsewhere on other implements / tractors other than the G so they might not be so rare.  I notice the back lift frame uses the same link thingy.
Anyway, if anyone has any, I'm interested.
cheers,
Creek
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2010 at 11:11am
Try Roger VanCamp, Fort Wayne IN. HTH Tracy Martin
Bruce Mn. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bruce Mn. Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2010 at 2:11pm
creek, Iv'e got a cultivater for mine if you want to look at the piece to try to make one. I don't know exactly what your talking about.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Creek Jenkins Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2010 at 3:24pm
Bruce -
It's the rod with a spring that hooks into the lift arms on one end and the tool carrier on the other.  On the tool carrier end there is a horizontal trunnion thingy.  I think the purpose is to allow the cultivator to raise up on a rock or whatever without bending the lift assembly.  I think it is made of 1/2" rod, bent 90 at one end, little trunnion on the other.
I'll have to give you a call and see if I can get down to see you - you around this weekend?
cheers,
Creek
norm [ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm [ind] Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2010 at 8:09pm
  we will check our inv. this week end  have an appt.fri morn at truck garage
 we have some extra parts  1-800-254-3116
This page was generated in 0.180 seconds.
