G hydraulic help needed |
Post Reply |
Canadian G
Bronze Level Joined: 23 Jun 2021 Location: Newcastle Ontar Points: 4 |
Posted: 23 Jun 2021 at 6:30pm |
hi, new here. Blew the front hydraulic hose ( likely original) on my G. Replaced hose. Topped up transmission oil. Now have no hydraulic pressure. Baffled...feel like I am missing something obvious. I use this tractor for cultivating and side dressing cauliflower, onions and sweet corn. Need it back in operation. Suggestions? Thanks.
Dusty MI
Orange Level Joined: 13 Sep 2009 Location: Charlotte, Mi Points: 5058 |
The PTO needs to be engaged/turned on for the hydraulic to work.
Dusty
Ted in NE-OH
Orange Level Joined: 12 Nov 2009 Location: Austinburg OH Points: 1703 |
Transmission oil is used for hydraulic system. Uses UTF Universal Transmission Fluid. check at big square plug on left side axel.
Canadian G
pto lever up or down to engage hydraulic pump? thanks
Canadian G
ok...crisis averted...cockpit error on my part. When I replaced the hose, I slightly rotated the tee at the pump output. The tee caused mechanical interference with the spring on the valve control rod so I was getting very little rotation of the hydraulic valve. Hard to admit I was that stoopid but my error might help someone else. Btw, lever goes down to engage hydraulic pump. Tractor serial is G5963 I think but I was reading it upside down and backwards while standing on my head. Thanks for the help. The G and I are headed to the cornfield.
Ray54
Orange Level Access Joined: 22 Nov 2009 Location: Paso Robles, Ca Points: 4505 |
Thanks for giving the happy ending. So many ask and never give us the good news of what they did to fix it.
Post Reply | |
