"G" Frame Question
John Updyke, Sr. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John Updyke, Sr. Quote  Post ReplyReply Direct Link To This Post Topic: "G" Frame Question
    Posted: 12 Jun 2012 at 10:12am
Why is there a half inch hole in the top of the frame over the special low gear transmission of the Allis-Chalmers "G"?  It would seem that water, dirt, yellow jackets, and all other sorts of unwanteds would enter via that uncovered opening.  I'm in the reassembly process of a complete restoration and puzzled.  Hopefully one of you has an answer for me.
1947 "B" w/ sickle bar. Complete restoration in 2006.
1948 "G" Complete restoration 2012
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2012 at 5:36pm
If you mean the hole right behind the seat bolts it's where the wiring runs through the frame on mine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote John Updyke, Sr. Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2012 at 10:06pm
Thanks for responding.  I realized, after threading a stiff wire down that hole, that the hole in question led  forward into the main frame and would not allow any unwanted debris to enter the special low gear housing.  I'll check pictures of other restorations and employ it for the wiring as you indicated.  This restoration of a 1948 "G" has become far more of a project than I first expected, and costly too.  Thanks again for your input.
