G drill planter
Lon(MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Topic: G drill planter
    Posted: 03 Oct 2017 at 7:29am
Are the Drive wheels for a G planter the same as a WD drill planter?
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2017 at 10:14am
One of the G implement manuals I showed the link for yesterday says the planter uses 18" wheels. The second section for drills doesn't say what the wheel sizes are.
http://www.geraldj.networkiowa.com/Trees/Model%20G%20Implement%20Setup%20(TM-3)%20PART%201.pdf
http://www.geraldj.networkiowa.com/Trees/Model%20G%20Implement%20Setup%20(TM-3)%20PART%202.pdf
Gerald J.
den/southern illinoi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote den/southern illinoi Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2017 at 10:23am
No, not the same.  Den
Own 4 wheel 20, 2-5015, 5020 and associated equipment and 2 electric forklifts.
This page was generated in 0.069 seconds.
