G creeper gear?
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2010 at 7:30am
Originally posted by PennsylvaniaNewt PennsylvaniaNewt wrote:
So does this mean the B and C tractors can be geared lower just like the G?  I had a C and it had plenty of power but was geared to high for careful brush hogging.
No, the gears and their housing is in the way for the torque tube.
Dusty
Dave(inMA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2010 at 7:32am
PANewt - not sure about your idea. I saw a caution in one of the posts above, that the low gear is not adequately supported for heavy duty work. Also, you'd need to change out the shifter  - the G service manual contains this language:
"The gear shift is the same as used on the Model "B-C", except, the guide plate is notched for the special low gear and the lever is shaped differently and guide pins are used to control lever."
But anything may be possible! It'd be great if it were useable in a heavy load situation for those of us who take their C's tractor pulling, but alas.......
Edited by Dave(inMA) - 22 Jan 2010 at 7:33am
WC, CA, D14, WD45
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2010 at 7:33am
One of my manuals shows/talks about bevel cut shift lever guide pins to be used when the G has the special low.
Dusty
Dave (Mid-MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (Mid-MI) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2010 at 5:56pm
I am looking through old sales mailers. None of them have specifications, as they cover several models. Every mention of the G states speed as low as 3/4 mph. The mailer from July, 1951 states "comes complete with starter and lights: four forward speeds". dave
J-WAG View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote J-WAG Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2010 at 6:08pm
I have a 1949 AC G and it only has 3 forward speeds and 1 reverse, so would first be the creeper gear?
Post Options Post Options   Thanks (0) Thanks(0)   Quote J-WAG Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2010 at 6:17pm
I just talked to my dad about this situation and he said the creeper gear was an option on G's for cultivating and stuff
                                                          Mine does not have one
