G Clutch Noise
PaxG View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaxG Quote  Post ReplyReply Direct Link To This Post Topic: G Clutch Noise
    Posted: 01 Apr 2010 at 7:48pm
Bought a new G, works great but it makes a squelching sound sometimes when the clutch is let out.  What is the problem?
'49 G, '51 G
Jeff Z. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff  Z.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2010 at 8:54pm
I would be looking at the bearing first.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2010 at 9:07pm
Maybe mice from setting too long. LOL I just recently got a G and am learning about it slowly. When I pulled my starter off there musta been a 3 gal bucket full of mouse nest in the flywheel housing. You might want to take a look. I don't know if there is an inspection cover underneath these little buggers but maybe someone else will chime in here.
allallis2 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allallis2 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2010 at 8:03am
It may just be from sitting. Mine sat in a shed for 15 yrs. before I bought it. had the engine and clutch out of it and the flywheel was a little rusty, could just be the case with yours. Take it for a ride or give it a job and work it a little and see what that does for it. Mine is still a little jerky when you first take off, nothing that will hurt. Check the free play too make sure it's not to tight. Needs to be about a 1'' of free play.
1955 G,1938 wc unstyled, 1938 A 1938 B, 1949 G
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2010 at 6:14pm
My guess is the pilot bearing.
Dusty
JimB IN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimB IN Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2010 at 7:28pm
There is a sheetmetal cover plate held on with 2 bolts on the engine side of the fly wheel housing near the bottom that you can take off and see in the bottom. I took it off and left it off and the mice don't build a nest in mine now. JB
Gil (cent MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gil (cent MO) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2010 at 8:07pm
I don't know what causes it but when you find out let me know. I have three, they all do it, one of them is my mower tractor and has a 42G Woods on it. I've used it that way for almost 30 years and it still squawks when you let the clutch out. I figure it can't be too much of a problem because I've never had any clutch trouble. The other two tractors are the same way I just don't use them for any serious work.
