G carb
randy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote randy Quote  Post ReplyReply Direct Link To This Post Topic: G carb
    Posted: 03 Mar 2017 at 12:43pm
Been working a carb off a G. I put a new kit, gaskets and needle and seat, but it keeps running over after i shut it off. The float doesnt leak, i tried a different float from another carb, same thing. Tried to adjust float height, still leaks. I am going to try the old needle and seat this afternoon, it doesnt have the rubber tip on the needle and try it.
Any ideas out there? It leaked berore and thats why i got the kit.
Thanks, Randy
Lon(MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2017 at 7:22am
Had a carb for a different tractor that leaked. Found that the gasket on the seat was leaking due to a pitted gasket surface. Just something I look for when rebuilding.
Post Options Post Options   Thanks (0) Thanks(0)   Quote randy Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2017 at 9:09am
Thanks, will check that out.
