"g" carb problems ?? |
wahl4m ![]() Bronze Level ![]() Joined: 23 Jan 2018 Location: norwalk iowa Points: 3 |
![]() ![]() ![]() ![]() ![]() Posted: 23 Jan 2018 at 1:41pm |
i rebuilt the carb -wouldnt start! installed one of another "g" -run good ! took both apart -& compared parts -ckd the mating surfaces ,floats & levels -cant see anything wrong ?? what am i missing ?any ideas ?? thanks mike
jaybmiller ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Greensville,Ont Points: 24703 |
plugged passage way ?
gasket wrong way ? it took me 3 'total tear down/clean/rebuilds' to get a CA hydraulic pump to run right... sorry,had 3 Gs, have none now to eyeball what it could be... jay |
HoughMade ![]() Orange Level ![]() ![]() Joined: 22 Sep 2017 Location: Valparaiso, IN Points: 707 |
Yeah, every time I've cleaned carb, it took several tries before it was good. Is it possible a gasket is flipped over and blocking a passage?
Edited by HoughMade - 23 Jan 2018 at 3:27pm |
1951 B
Gerald J. ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Hamilton Co, IA Points: 5636 |
http://geraldj.networkiowa.com/Trees/Allis-Chalmers-G-B-C-CA-Service.pdf
should show all the carburetor assembly and tuning details. Gerald J. |
ckd all passages /gasket will only fit 1 way w/ float-i chd surfaces for warpage -all ok ! guess ill take it apart again ?? thanks
drobCA ![]() Orange Level ![]() ![]() Joined: 20 Jun 2017 Location: Perris, CA Points: 292 |
I had what I guess was a stuck float on a brand new carb.
disassembled, found no problems, reassembled = works fine. not the first time a take apart/reassembly doing nothing else has "fixed" whatever.
3 Ford 8N's I loan to neighbors, but the '52CA, '41B and little B1 I do not.
Larry in NC ![]() Orange Level ![]() Joined: 09 Feb 2016 Location: NC Points: 1050 |
From my experience, the usual problem is a clogged jet, but I cleaned the carburetor on my son's G and it would still would not run. When I pulled the carburetor apart a second time, there was no gas in the bowl. The problem was the float valve sticking. The valve was new, so I tried again and it did not work. Finally found a used valve and installed it and the tractor ran fine. Even new parts are not a guarantee.
