fwa vs twd
19856020 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 19856020 Quote  Post ReplyReply Direct Link To This Post Topic: fwa vs twd
    Posted: 02 Feb 2017 at 2:36pm
hope im not beating a dead horse with this question, but what if you had (for example) an 8050 fwa pulling the correct size chisel plow, and an 8050 twd pulling a smaller plow - throttle back a litte - could you get the same amount of work done using the same amount of fuel only more time
716 917 918 1920 d17 6080
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2017 at 2:52pm
Depends on soil conditions
Tenn allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tenn allis Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2017 at 3:46pm
Most efficient is gonna be fwa no matter conditions I only time not as efficient as if your cutting hay or baling when you don't need fwa personally I wouldn't buy anything but a fwa anymore
Dswall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dswall Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2017 at 7:09pm
More Acres per hour usually calculates to better fuel efficiency
Dustin in CA
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2017 at 8:19pm
Better fuel economy because all the power goes to the ground instead of lost to slippage.
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2017 at 10:29am
x2
Allis actually did tests on 2wd vs FWA for the customers showing the advantages and fuel saving of FWA, and they even offered free FWA for a while. I forget what model 8000 series (I think 8070) with FWA could do as much work as a 4W220, but on less fuel.
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2017 at 11:03am
x2
I see the 8070 using less fuel but call bull on being able to do the same work my 8030 MFD dualed up will spin out before my 7580 does.
Edited by victoryallis - 03 Feb 2017 at 11:10am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2017 at 11:25am
An 8070 is 3000lbs heavier than a 8030. I think a big part of the sales argument was that the 8070FWA cost less than the 4WD tractor and could do almost the same job. It should do almost the same as they're the same HP. Now we're back to Allis old sales pitch of pulling smaller implements faster. Depends on what you're really doing for hard tillage I suppose.
I'm a big 4WD fan though. They float so much better and have so much more pull to get through wet spots and all that weight and stability is nice on a grain cart too.
But now we're digressing from the original question...
jiminnd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jiminnd Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2017 at 11:38am
Not set up properly but when Magnum came out we had a demo, fwd we had on a disc, rum in twd and them flip the switch to fwd, unbelieveable but no duals so a twd with duals would make a difference.
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2017 at 7:28pm
True but my 8030 has radial 20.8's that are loaded and the 7580 has empty 18.4's bias tires.   We have a J&M 875 grain cart I can put 2/3 of a load in it and the 7580 will drag it places I would be afraid to drive a 4wd pick up.
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2017 at 6:33am
I've noticed this phenomenon too, but you're also pushing different tires and a heavier front end through the dirt than a 2wd would be in that case.
Edited by Tbone95 - 04 Feb 2017 at 9:04am
Post Options Post Options   Thanks (0) Thanks(0)   Quote 19856020 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2017 at 9:24am
thanks for all replies but still wonder if one could get same work done on same amount of fuel using a two wheel tractor w radial duals in ideal conditions pulling a much smaller implement ? . no question that fwd always better!! . p.s. my dad let me skip school the day they demo'd 6000/8000 fwd they pulled a big disk w 8050 flipped switch on amazed everyone , almost converted the landowner from red to orange,also remember at one point that big disc was hooked to 6080 fwa to move to another field we put it in the ground just for fun and it blew everyone away that it could pull it no prblem
jwal10 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jwal10 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2017 at 11:49pm
125 hp is about the break point here. Over needs a lot more weight at max load, using a lot more fuel. At 125 hp, weighted light and gear higher was more efficient. 5 bottom plow, singles, in furrow was a lot more efficient than weighted heavy, duals, 4wd and onland pulling 6 bottoms. If powering around corners like seeding, duals and 4wd worked well as the 4wd pulled you right around, not having to use brakes. Medium load throttled back 200 rpm....James
GM Guy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GM Guy Quote  Post ReplyReply Direct Link To This Post Posted: 19 Feb 2017 at 11:57am
I think the figures for the FWA are the Gallons per Hour figure is higher due to the reduced efficiency due to drag in the drivetrain, but the Gallons per Acre figure is more efficient due to the increased traction.
We either own 4wds or 2wds, only if they can be bought cheap will we own FWAs, they are nice for some applications, but IMO the high cost of repairs offset any gain for us.
If you need parts for your Gleaner, we are parting out A's through L2's, so we may be able to help.
