Furnace Filter Price |
Dave H
Joined: 11 Sep 2009 Location: Central IL Points: 3611 |
Topic: Furnace Filter PricePosted: 05 Apr 2026 at 9:40am |
28X34 MERV 11 This is apparently an odd balll size. Right now I have some in the cart on amazon for $27.42 a pop. Anyone aware of a more economidal source? According to my math, that equates to approx 30 cents a day with a 90 day change interval.
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 25274 |
Posted: 05 Apr 2026 at 10:49am |
yeesh... are they 1", 2" or 4" thick ?? hopefully Google can find cheaper ones.
PaulB
Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5279 |
Posted: 05 Apr 2026 at 7:03pm |
Get some that are half the size on one side and tape 2 together. That's what I do to get a 30'X31" without paying a fortune.
Dave H
Posted: 05 Apr 2026 at 7:20pm |
Jay, they are rated as 1 in thich and seem to be more like 3/4
Paul. I will get on that trail tomorrow. BTW what kind of tape do you use ?
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42274 |
Posted: Yesterday at 12:32am |
https://filterking.com/air-filter-sizes/28x34x1a?utm_source=google&utm_campaign=&utm_term=&lebesgue_source=google&lebesgue_adid=&lebesgue_campaign=22909955419&gad_source=1&gad_campaignid=22905828374&gbraid=0AAAAADDCy-ElFXZjoNgd_Xa0XZCwb0T0D&gclid=EAIaIQobChMIjYn1vr_YkwMVQzIIBR0FIBr_EAUYASAAEgJi0_D_BwE < jsuid="Ot4LZc_5m" ="0" -amic="true" -icl-uuid="8aaf6b40-2c85-4901-b675-3c13d2d00492" aria-label="View related s" ="rBl3me" js="click:&Ot4LZc_5k|S9kKve;mouseenter:&Ot4LZc_5k|sbHm2b;mouseleave:&Ot4LZc_5k|Tx5Rb" -wiz-attrbind="=Ot4LZc_5k/C5gNJc;aria-label=Ot4LZc_5k/bOjMyf;=Ot4LZc_5k/UpSNec" -ved="2ahUKEwi92ae8v9iTAxVGpIkEHW3fE-QQye0OegQICBAA" -hveid="CAgQAA" style="margin: 0px 6px 0px 0px; : rgb233, 235, 240; border-width: initial; border-style: none; border-color: initial; border-radius: 10px; height: 20px; padding: 0px; width: 20px; outline: 0px; cursor: pointer;">http://www.w3.org/2000/svg" viewBox="0 0 24 24"> Because 28x34x1 is a non-standard size, some manufacturers tape two smaller filters together to achieve the final dimension, which is an industry standard practice that does not affect performance. Always check the actual dimensions of your current filter to ensure a snug fit, as "Exact Fit" versions may differ slightly from "Nominal" versions. < jsuid="Ot4LZc_5r" ="0" -amic="true" -icl-uuid="1b05a6f6-273e-4ed4-ade4-1ed6de36a2af" aria-label="View related s" ="rBl3me" js="click:&Ot4LZc_5p|S9kKve;mouseenter:&Ot4LZc_5p|sbHm2b;mouseleave:&Ot4LZc_5p|Tx5Rb" -wiz-attrbind="=Ot4LZc_5p/C5gNJc;aria-label=Ot4LZc_5p/bOjMyf;=Ot4LZc_5p/UpSNec" -ved="2ahUKEwi92ae8v9iTAxVGpIkEHW3fE-QQye0OegQICRAB" -hveid="CAkQAQ" style="margin: 0px 6px 0px 0px; : rgb233, 235, 240; border-width: initial; border-style: none; border-color: initial; border-radius: 10px; height: 20px; padding: 0px; width: 20px; outline: 0px; cursor: pointer;">http://www.w3.org/2000/svg" viewBox="0 0 24 24"> Would you like to compare bulk discounts for these filters, or are you looking for a washable permanent alternative instead?
Edited by Coke-in-MN - Yesterday at 12:35am |
Joined: 11 Sep 2009 Location: illinois Points: 90895 |
Posted: Yesterday at 2:02pm |
i doubt your going to find it cheaper to buy two filters and tape them together... 28 x 34 is a BIG FILTER... not sure why it needs to be that big unless that furnace is HUGE.. our 80,000 BTU furnace uses a 20 x 20 filter..... check the OUTLET size and see if the INLET could be framed smaller... 28 x 20 or 24 x 30 might be more common and might be all you need for square inches ??
You can save a little by going to MERV 8 instead of MERV 11... depending on your needs.
DMiller
Joined: 14 Sep 2009 Location: Hermann, Mo Points: 35704 |
Posted: Yesterday at 4:05pm |
Might be worth buying a constructed High Efficiency Washable we did on our HP 30x30x2. Keep one throwaway to install as wash out permanent then it dries and goes back in.
Edited by DMiller - Yesterday at 4:06pm |
Dave H
Posted: 11 hours 49 minutes ago at 9:41am |
Steve, you about summed it up. Think I will keep diging deep in the pocket for now.
Yep I do think she is "over filtered""
Coke-in-MN
Posted: 8 hours 51 minutes ago at 12:39pm |
Other thing is to look at filter roll material and a frame to hold the media , I used the product on large air handlers then adapted it to home furnace .
