Furnace Filter Price
Dave H View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H Quote  Post ReplyReply Direct Link To This Post Topic: Furnace Filter Price
    Posted: 05 Apr 2026 at 9:40am
28X34 MERV 11  This is apparently an odd balll size.  Right now I have some in the cart on amazon for $27.42 a pop.  Anyone aware of a more economidal source?  According to my math, that equates to approx 30 cents a day with a 90 day change interval.  Confused
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2026 at 10:49am
yeesh...
are they 1", 2" or 4" thick ??
hopefully Google can find cheaper ones.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2026 at 7:03pm
Get some that are half the size on one side and tape 2 together. That's what I do to get a 30'X31" without paying a fortune.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H Quote  Post ReplyReply Direct Link To This Post Posted: 05 Apr 2026 at 7:20pm
Jay, they are rated as 1 in thich and seem to be more like 3/4
Paul.  I will get on that trail tomorrow.  BTW what kind of tape do you use ?
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2026 at 12:32am
https://filterking.com/air-filter-sizes/28x34x1a?utm_source=google&utm_campaign=&utm_term=&lebesgue_source=google&lebesgue_adid=&lebesgue_campaign=22909955419&gad_source=1&gad_campaignid=22905828374&gbraid=0AAAAADDCy-ElFXZjoNgd_Xa0XZCwb0T0D&gclid=EAIaIQobChMIjYn1vr_YkwMVQzIIBR0FIBr_EAUYASAAEgJi0_D_BwE
Buying Tip: Nominal vs. Actual Size
< jsuid="Ot4LZc_5m" ="0" -amic="true" -icl-uuid="8aaf6b40-2c85-4901-b675-3c13d2d00492" aria-label="View related s" ="rBl3me" js="click:&Ot4LZc_5k|S9kKve;mouseenter:&Ot4LZc_5k|sbHm2b;mouseleave:&Ot4LZc_5k|Tx5Rb" -wiz-attrbind="=Ot4LZc_5k/C5gNJc;aria-label=Ot4LZc_5k/bOjMyf;=Ot4LZc_5k/UpSNec" -ved="2ahUKEwi92ae8v9iTAxVGpIkEHW3fE-QQye0OegQICBAA" -hveid="CAgQAA" style="margin: 0px 6px 0px 0px; : rgb233, 235, 240; border-width: initial; border-style: none; border-color: initial; border-radius: 10px; height: 20px; padding: 0px; width: 20px; outline: 0px; cursor: pointer;">http://www.w3.org/2000/svg" viewBox="0 0 24 24">
Because 28x34x1 is a non-standard size, some manufacturers tape two smaller filters together to achieve the final dimension, which is an industry standard practice that does not affect performance. Always check the actual dimensions of your current filter to ensure a snug fit, as "Exact Fit" versions may differ slightly from "Nominal" versions. < jsuid="Ot4LZc_5r" ="0" -amic="true" -icl-uuid="1b05a6f6-273e-4ed4-ade4-1ed6de36a2af" aria-label="View related s" ="rBl3me" js="click:&Ot4LZc_5p|S9kKve;mouseenter:&Ot4LZc_5p|sbHm2b;mouseleave:&Ot4LZc_5p|Tx5Rb" -wiz-attrbind="=Ot4LZc_5p/C5gNJc;aria-label=Ot4LZc_5p/bOjMyf;=Ot4LZc_5p/UpSNec" -ved="2ahUKEwi92ae8v9iTAxVGpIkEHW3fE-QQye0OegQICRAB" -hveid="CAkQAQ" style="margin: 0px 6px 0px 0px; : rgb233, 235, 240; border-width: initial; border-style: none; border-color: initial; border-radius: 10px; height: 20px; padding: 0px; width: 20px; outline: 0px; cursor: pointer;">http://www.w3.org/2000/svg" viewBox="0 0 24 24">
Would you like to compare bulk discounts for these filters, or are you looking for a washable permanent alternative instead?
Edited by Coke-in-MN - 06 Apr 2026 at 12:35am
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2026 at 2:02pm
i doubt your going to find it cheaper to buy two filters and tape them together...  28 x 34 is a  BIG FILTER... not sure why it needs to be that big unless that furnace is HUGE..  our 80,000 BTU furnace uses a 20 x 20 filter..... check the OUTLET size and see if the INLET could be framed smaller... 28 x 20 or 24 x 30 might be more common and might be all you need for square inches ??
You can save a little by going to MERV 8 instead of MERV 11... depending on your needs.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2026 at 4:05pm
Might be worth buying a constructed High Efficiency Washable we did on our HP 30x30x2. Keep one throwaway to install as wash out permanent then it dries and goes back in.
Edited by DMiller - 06 Apr 2026 at 4:06pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2026 at 9:41am
Steve, you about summed it up.  Think I will keep diging deep in the pocket for now.
Yep I do think she is "over filtered""  Confused
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2026 at 12:39pm
Other thing is to look at filter roll material and a frame to hold the media , I used the product on large air handlers then adapted it to home furnace .
