Fundamental Plow Question
Osage_Orange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Osage_Orange Quote  Post ReplyReply Direct Link To This Post Topic: Fundamental Plow Question
    Posted: 11 May 2011 at 11:41pm
I've seen 3_14's, 3_16's, 2_12's, 2_14's, and 2_16's mounted on tractors and can usually distinguish between each.  BUT................how are the different sizes defined? (moldboard size, distance between bottom of moldboards, etc).  By the size plows I'm talking about, you can pretty well guess my age (heh heh), but I've never heard or seen how the sizes are actually determined.
Why is there never time to do it right the first time, but always time to go back and fix it?
427435 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 427435 Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2011 at 12:11am
The first number is the number of plow bottoms and the second is the width of cut of the bottom (when the plow is properly set).  In order words, a 3-16 will plow a swath 48" wide.
Mark
B10 Allis, 917 Allis, 7116 Simplicity, 7790 Simplicity Diesel,
GTH-L Simplicity
Ignorance is curable-----stupidity is not.
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2011 at 8:07am
Measure plow width between the plow beams perpendicular to the beams or the direction of travel, usually 12, 14, 16, or 18 inches.
Gerald J.
ky wonder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ky wonder Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2011 at 4:21pm
you measure the width between the beams as in this photo, you will see it is 14 inches between the beams
Edited by ky wonder - 12 May 2011 at 4:25pm
i like old tractors of all colors
Rfdeere View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rfdeere Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2011 at 5:08pm
   Measuring beam to beam is not always correct. I have had plows that had a offset to the standard going down to the frog, thus the beam to beam was not the bottom size.
http://www.rumelyallis.com
