Ful-flo pics for JC(WI) and Don Dttmr
Steve M C/IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve M C/IL Quote  Post ReplyReply Direct Link To This Post Topic: Ful-flo pics for JC(WI) and Don Dttmr
    Posted: 19 Jan 2011 at 6:26pm
I'm not polished at posting pics but here goes
The base had 2 straight down fittings from the ser 4 but the inside port couldn't go down and then forward to the block because of steering shaft so I switched ends around (90deg VS straight) and got the combination with the addition of a short coupled 90 to use in the upper hole on block because the factory 90 had too much "swing" and hit the old pressure reg housing.The outer pipe on filter hsg is original but I had to take about 3/8in off each end to get the fit.The inner pipe got the bend reversed on the block end to aim it where it needed.Kinda tricky with the old hand bender but not impossible.Had a new piece of 1/4 brake line for making new but didn't need it.
Leftovers...oil pump,press reg&spring,plumbing,filter base
I used a full-flow pump from an E gleaner cause the donor tractor that I got the base and lines/fittings etc wouldn't let go of the pump.This pump has the pressure reg built in.Should've took pics of proceedures(drilling,tapping,plugging)but I didn't.
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2011 at 7:04pm
Steve, Y ou did fine posting them pics, I was hoping for just one or two but NINE, that was really just fine.
  Was planning on doing something like that when I take apart my early D17 engine.
  That was Great! Guess now you can ebay the other parts and get some cash back maybe.
Bill_MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill_MN Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2011 at 8:47pm
is that line going back past the PS pump for a remote oil gauge? if not what kind of gauge setup do you have?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2011 at 9:06pm
The part of the conversion unseen is the drilling, tapping and plugging that goes on inside the block before all the outside stuff can be attached. Also getting the correct oil pump and drive gear on the top of the oil pump is crucial to success of the changeover.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve M C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2011 at 9:28pm
Bill;That is for the oil pressure guage.You can't see around a factory PS gear to see an original guage.The TB guage didn't work so I staitened out the line and used it for oil pressure guage which is mounted in place of the TB guage.That was 30 yrs ago.Today I would not have molested the "original" TB feed line,but I have a different perspective now.
DonDittmar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonDittmar Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jan 2011 at 6:16am
NICE...Thanks for posting
1968 D15D,1962 D19D
