Fuel tank selector valve…………..
Lars(wi) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Topic: Fuel tank selector valve…………..
    Posted: 18 hours 58 minutes ago at 6:27am
Acted up the other day on the ‘91 F-350 7.3L IDI. For a day, was drawing fuel from both tanks. This following about 6 weeks adding a small bottle 2-cycle oil at every fill-up to aid with pump lubrication while pulling that heavy camper across the country.
My question is; is the 2-cycle oil being added to diesel cause the pistons in the selector valve to get ‘sticky’ and possibly ‘hang up’?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 18 hours 25 minutes ago at 7:00am
Two Cycle Oil is not meant for Diesels, may be a lubricant in two stroke engines, is actually too Viscous even diluted for Fuel Injection Systems.  Same issues were found using filtered Waste Engine oils to fuels as a Extender and to consume the waste.
Simple Answer Yes.
BTW, significant add on, for those adding ATF to fuel tanks for Lubricity, is perfectly fine on OFF Road machines, for on Highway is NOT as the materials in ATF can foul all manner of Emissions devices if have not been dealt with, as well using previous version that are RED, the chances of being caught as use of AG Diesel on Hwy. becomes more prevalent.  Friend of ours had 'Treated' his Home Tank of ON Hwy Diesel with ATF, delivering agent noted was RED in Color and cautioned to deaf ears, was a Spot Check at a Grain delivery site and he was TICKETED for Dyed Fuel, truck was placed OOS until the Fuel supply was fully cleaned and cleared.  And NO, there is NO test that can confirm was Not AG Fuel.  ALL Diesel comes from same truckloads, Dye is added as Complete AG tank Fillings.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 17 hours 58 minutes ago at 7:27am
If anyone wishes to a a lubricant to Diesel fuel, especially ON Highway fuel, They should use a product specifically for ON Highway fuel such as PowerService injector cleaner. This is the only product that is made by a diesel engine company. There is also a comparable Standyne product made by a Diesel injection products company. These products are "water clear" and won't be an issue when spot checked, which any diesel vehicle driven on the highway is subject to. Oils of any kind could have enough dye of any color that would be detectable in a test. Anything else I'd consider to be snake oils or homebrews which may work just fine for some and create big problems for others. I would also only use the above products in OFF ROAD fuels as homebrews are like playing Russian Roulette.
  Having been a bulk transporter of fuel for many years starting before the introduction of ULSD, I have encountered first hand the complaints from those that tried to save a penny with their own homebrews for lubication when the sulfur started to be removed from diesel fuel.
  However anyone is welcome to use whatever they like, DO YOU FEEL LUCKY?
Edited by PaulB - 17 hours 56 minutes ago at 7:29am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 17 hours 52 minutes ago at 7:33am
I chose the 2-cycle oil as hopefully finding a pump lubricant that is also designed to ‘burn, unlike atf or used engine oil that is not intended to ignite. I will give it a couple fill-ups without adding anything and see if the issue clears itself.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 17 hours 35 minutes ago at 7:50am
I remember when ‘dyed’ off-road fuel concept first it the market. Some was red, some was blue, the blue diesel didn’t last long because of the potential of being mistaken for aviation fuel, that was(at the time tinted blue). Some loading facilities were slow to install the dye injection equipment at the racks, so we had to splash blend the dye. At first we could add the fuel at the customers tank, then we had loading facility personnel witness us dumping the dye in the compartments of the tankers at the facility. The fun times.
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 3 hours 5 minutes ago at 10:20pm
When I was hauling tanker trucks , loading diesel into truck compartment ( 4 section trailer ) the loading slip at the refinery automatically injected die as that slip contained loading instructions on how many gallons (pounds) of fuel was on total order .
 Yes ATF can color fuel to get DOCKED by fuel sampling by DOT compliance .
Had MN Highway Patrol ( Truck Div ) stick tanks on dump trucks often , use to ask them if they wanted to stick backhoe or dozed also as I only bought ON ROAD fuel just to prevent someone screwing up and transferring the wrong fuel
This page was generated in 0.067 seconds.
