fuel tank liquid liner
Leon B MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Topic: fuel tank liquid liner
    Posted: 10 Dec 2010 at 8:11pm
We have a very small leak in the bottom of the fuel tank on the 200. Just enough to make the whole back end a mess. It has been patched once before. Will the tank liners that are used for gas tanks stand up to diesel as well? Anybody have a good supplier?
Thanks again.
Leon B MO
Jeff Z. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff  Z.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 10 Dec 2010 at 8:19pm
Call them with diesel question.
http://search.eastwood.com/search?asug=&w=tank+sealer&p=Q&ts=custom&x=16&y=12
Bertman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bertman Quote  Post ReplyReply Direct Link To This Post Posted: 11 Dec 2010 at 3:09pm
Red-kote works great. Need to get rid of all the diesel residue. If tank is clean and has no rust flush it with acetone oe MEK, Let dry and coat inside. Need to put atleast 2 quarts in to coat the in side. Id try 3 quarts if it was me
Dave in il View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave in il Quote  Post ReplyReply Direct Link To This Post Posted: 11 Dec 2010 at 10:18pm
If I was going to take the tank off I'd see if a radiator or weld shop coul repair the leak.
