Fuel Tank Cleanout & Liner
ACEd2010 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACEd2010 Quote  Post ReplyReply Direct Link To This Post Topic: Fuel Tank Cleanout & Liner
    Posted: 27 Apr 2012 at 11:44am
Need advice on cleaning out an out fuel tank with goey crud on bottom - thinking of putting a gallon of used carb cleaner and letting it soak. Any comments / suggestions welcome
Second question applies to a different tank which is clean with minimal rust - what tank prep and liner is best in these days of alcoholic gas. Not planning to use alcoholic gas if i can help it, but who knows what future will bring.
David Maddux View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David Maddux Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2012 at 11:58am
Probably a gallon of laquer thinner would be cheaper than carb cleaner and would do as good a job. I am partial to the red-kote liner. They claim that alcohol will not hurt their liner. Excellent directions on their web site.
Don(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2012 at 12:13pm
I will 2nd the red-kote....If you want nothing but pure fuel in the sediment bowl, use this stuff. Was thinkin about that the other day, looking at the sed. bowl on the WC
Galatians 5:22-24
Dave Richards (WV) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave Richards (WV) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2012 at 12:34pm
I have used red-kote in the D-12 for about 12 years now.  Still looks like the day I put it in.  Have to use Corn-a-hole gas here, cant get any other.  Since you are doing a fuel tank, make sure you replace any rubber fuel lines with metal.
Richardmo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Richardmo Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2012 at 8:21pm
I start with  oven cleaner if there is a lot of old fuel turn to tar this seems to loose  and help remove and clean the tank the best i have had to do this with my last 3 tanks.
Then i like POR 15 they have  a 3 step system i flow the directions done at least 12 tanks with there system good results.
Also if there is a lot of rust i use muriatic acid be carefull if the tank is bad it will eat through the tank and do not get any on you.
I had to use this only once.
Make sure your tank is completly dry before you use the sealer.
Dale H. ECIL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dale H. ECIL Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2012 at 8:31pm
I have used the Red-Kote for several years and had good results. If I get a tank that is really dirty I will clean it out with Muratic acid, be careful not to breath it, strong stuff. Also rinse it out good and made sure it is dry before using the Red-Kote.
Allis Chalmers Museum, Paris, Il.http:// www.allischalmersmuseum.com 217-275-3428
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2012 at 9:56pm
I used POR-15 on my one-seventy about 6-7 years ago.  No issues with it.
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
Leonard View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leonard Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2012 at 12:46am
I swear  by POR-15.  Have used it in numerous tanks and have never had a problem.  Very easy to use and reasonably priced.
Leonard
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2012 at 12:57am
Most people use HCL acid for rust removal Muriatic  Acid ( inhibited ) will remove the rust and will attack the base steel also over time. Problem is the fumes given off can be a real irritant. You can also use Sulfuric Acid for the rust removal it's a little slower but less funes. Only problem is it's hard on clothes .
 Several good tank liners out there just be sure they will stand up to the alcohol.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedBuiskerN.IL. Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2012 at 9:16am
Acetone works pretty good on the gooey part, then I let it dry and vacuum as much of the loose rust out as I can after the log chain in the tank tarp strapped to the rear wheel trick.  Then I use a new sediment bowl with the little nipple on it that sticks up into the tank a bit, or modify the original with a short piece of copper tubing.  Can't run the tank dry, but the system has been trouble free so far.  (20 plus years)
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACEd2010 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2012 at 1:02pm
Thanks for the inputs - its RedKote or POR-15. I think local O'Reillys has RedKote in gallons for $55 - so that may be quickest option once I get goop out.
79fordblake View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79fordblake Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2012 at 8:29pm
How big is your tank? I bought a quart of red-kote for the tank on my WD45 and I put two coats in it and didn't use the whole quart.
