fuel shutoff solenoid |
rbaggett ![]() Bronze Level ![]() Joined: 08 Dec 2010 Location: Texas Points: 18 |
![]() ![]() ![]() ![]() ![]() Posted: 21 Jan 2023 at 1:50pm |
I have a 6080 AC that is getting fuel to the injection pump but will not start. I have power to the fuel shutoff solenoid when the switch is on but I don't hear it click like it normally does and I am getting no fuel to the injection nozzles. Does anyone have any suggestions on how to fix this. It was starting just fine this morning but when I went back to start it would not start.
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 22001 |
If it isn't clicking and you're certain you have good power to it, the shut-off solenoid is bad. You might try and run a new wire from the battery post on the starter hot cable direct to the injection pump and see what happens. Just because you may light a test light doesn't mean it is a good 12 volt signal under load.
