Fuel Question
Message Reverse Sort Order
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Topic: Fuel Question
    Posted: 31 Aug 2025 at 9:10am
Seems like some people or areas of the country have problems with the ethanol if it sets for a few weeks... Others have no problem with it setting 4-5 months at a time.. Maybe its the humidity or temp changes...
Yup.
Here in northern Idaho our climate is nowhere near as humid as yours is in the midwest, but it is also not as dry as the southwest.
What we do experience here is significant cooling at night; it is a rare summer night when it doesn't drop into the 50's, and mid 40's is common. This pushes the temperature below the dew point on a regular basis, causing a considerable amount of moisture to condense on the inside of fuel tanks, etc.
My 1941 John Deere Model A tractor has a large crankcase, and the transmission/final drive gearbox is bigger yet. I park this tractor inside a shed that does not leak, and over the course of a long winter I can drain nearly a quart of water out of the crankcase come springtime, and almost twice that much from the gearbox. This is all due to condensation from the air. Fuel tanks do the same thing.
Folks in our area had a lot of trouble caused by ethanol until the non-ethanol fuel became readily available, and not everyone is aware of it still. The small engine repair guys don't seem to mind though TongueWink
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2025 at 8:00am
there is no gas station within 50 miles of me that sell non-ethanol... thats all we got for EVERYTHING..
Seems like some people or areas of the country have problems with the ethanol if it sets for a few weeks... Others have no problem with it setting 4-5 months at a time.. Maybe its the humidity or temp changes. I have not had a "carburetor crud" problem with it setting for 4 months.
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2025 at 5:28am
I've always ran the cheapest gas I could find.  E10 or E15 here.  Never had a fuel issue.
AaronSEIA
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2025 at 5:10am
Originally posted by Lars(wi) Lars(wi) wrote:
Around these parts, the non-ethanol 87 octane is priced 50-55 cents per gallon higher than the 87 octane ‘regular unleaded’, what have you guys noticed for a price difference?
Lars, the non-ethanol penalty around here varies from 10-40 cents a gallon at the station I use. I watch prices, when they are down I stock up.
Lars(wi) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2025 at 8:46pm
jvin248 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jvin248 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2025 at 6:01pm
If you use a motor every day or week you can pour whatever witchcraft ethanol you want into it.
But if the engine sits, like that prized restoration tractor or car or pickup or snowblower or lawnmower sitting for months off season, avoid all ethanol.
Splurge on recfuel recreation fuel and you won't need to fiddle trying to fix the carb every time.
https://youtu.be/iWL7p0Pnb8Y
https://youtube.com/shorts/EywwG906JMI
https://youtu.be/TQZK-hcl5M4
My father's favorite utility tractor, a Ferguson 35, sat for twelve years after he passed. I was able to get it started with the fuel in the tank since he put non ethanol in it.
I left ethanol in a push mower five years and it rotted out the carb bowl and leaked all the fuel (probably saved it).
Fuel conditioners just take your money. Don't believe them.
Be really careful out there, we put a huge amount of work into restoring these machines so choose fuel so they can farm and feed the next generation.
Edited by jvin248 - 30 Aug 2025 at 6:06pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2025 at 4:33pm
I have logged just about 1 million miles on 7 Ford pickups since 1982. Zero problems. Same goes for about 10 other cars and minivans. Zero trouble. I have 12 years of tractor rides and some plowing demonstrations on my WD-45 with nothing but ethanol fuel. When it gets put away for the winter, I shut off the sediment bowl and let it run dry. The tractor sits for 6 months with a 1/2 tank or more of ethanol and never once in 12 years have I had any issues. Engine probably gets 50 to 60 hrs per year on it. My One-Seventy high deck tractor uses ethanol for the last 5 years. No problems. Same fuel used in my D-10 and no problems. The only thing I won't use ethanol in is my lawn mower.
Edited by DrAllis - 30 Aug 2025 at 6:10pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2025 at 9:21am
Last Spring I was at a friend's house; he was trying to get his Ford Bronco running after it sat all winter. The carburetor was full of what I call "Donkey Snot" from the ethanol. He took the carb to a mechanic to get it fixed.  A couple of weeks later we chanced to meet up at the local gas station where I was pumping premium non-ethanol gas into my 1985 F-150 and he made a snide comment about how he couldn't afford to buy that expensive gas... Ermm
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2025 at 8:42am
i sure dont understand the problwm with ethanol fuel... I fill the truck every 6 weeks as we dont use it much.. Wifes car is every couple weeks... 4-5 small tractors that only cut grass in the summer and leave a gallon or so in each for 4 months at a time, and never had a problem..
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2025 at 8:38am
Originally posted by Rick of HopeIN Rick of HopeIN wrote:
everything around here (with no license plate) runs strictly on non ethanol these days.  Really helped reduce issues.  I have not had any luck with additives.
Now that I am retired I don't drive my pickup enough to keep the ethanol fuel rotated through it so even though it is licensed it only gets non-ethanol. My Wife's car has become our primary transportation and gets driven at least once a week so I use the cheaper ethanol fuel in it.
Rick of HopeIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick of HopeIN Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2025 at 8:01am
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2025 at 6:00am
Non-ethanol for me! It's fine as long as it keeps moving through the system. If it sits for awhile it's going to draw moister and that causes problems.
55allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2025 at 5:56pm
I generally use unleaded premium with no additives.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2025 at 12:10pm
Originally posted by ac160 ac160 wrote:
I use no ethanol premium unledead in all of my gas tractors and small engines along with stabil if they will sit for awhile.   Haven't had any issues.
X2
If I were planning to run my old tractors enough to keep the fuel rotated frequently then I would use the cheaper unleaded with ethanol in it but I would be careful to make certain to get all of the ethanol out of the entire system before parking it for the winter.
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2025 at 11:46am
I've been told that a WD45 already had hardened valve seats and to run unleaded gas.
unleaded goes in all our old tractors with no lead additives used.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2025 at 10:21am
I've burned unleaded 87 in my WD and 45 for as long as it's been around. 40 yrs? Have had no problems. Worst case scenario is pull head and put hardened seats in. I say don't worry about it.
ac160 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac160 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2025 at 10:15am
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2025 at 9:43am
I bought a 1989 F250 brand new... 35 years ago... WE have had Unleaded  85%  since the day i bought it....... Every tractor, mower, chainsaw, car, truck i have has been burning that for over 35 years.
DanM71 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanM71 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2025 at 8:29am
Morn'n Folks, I just bought a WD45 and want to know what kind of gas/additives should I use given that regular leaded gas is not available?
Thanx, Dan
This page was generated in 0.441 seconds.
