Fuel Quantity Left In the Hose ?? |
FREEDGUY
Joined: 15 Apr 2017 Location: South West Mich Points: 5396 |
Topic: Fuel Quantity Left In the Hose ??Posted: 02 Aug 2020 at 5:09pm |
Went to the local gas station to fill up a 2 1/2gallon can of mower gas with premium fuel at a Marathon station. I knew there would be some residual "regular" in the hose and pumped the first 2 gallons into the truck and then put the remaining gallons into the mower can. Was I close in "guesstimating" the gallons in the "average" dispenser/pump quantity ? Thanks
Joined: 11 Sep 2009 Location: illinois Points: 90812 |
Posted: 02 Aug 2020 at 5:36pm |
my mower and truck both run on 10% Ethanol.
FREEDGUY
Posted: 02 Aug 2020 at 5:42pm |
I've got no issue with ethanol, normally I run mid-grade but it takes me a year to burn through 2 1/2 gallons (small lawn) and thought maybe premium would bring some "snap" back to the old Honda
. Believe me, I burn my share of E-10 in the 5.4 .
Grayray
Joined: 12 Sep 2009 Location: Ambridge PA Points: 3860 |
Posted: 02 Aug 2020 at 6:21pm |
To find how much fuel would be in the hose, find the area of the inside diameter of the hose, then multiply by the length of the hose in inches. There are 231 cubic inches in a gallon, so divide by 231 and that should tell you how many gallon are in the hose. For example, the hose is probably one inch inside diameter, probably a little less. Using that, the radius would be 1/2 inch. area=pi times radius squared. Or 1/2 x 1/2 x 3.14159=.7853. Assuming the hose is about 10 feet long, or 120 inches, 120 x .7853=94.25. Now divide by 231 and we get .408 or a little less than half a gallon in the hose.
If the hose is a little longer, there should still be only about 1/2 gallon or less in the hose.
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 25254 |
Posted: 02 Aug 2020 at 6:31pm |
never really thought about it...be nice to get the 'left over' from someone buying premium though.... also makes sense why diesel is always by itself.... well today hasn't been a total loss... Jay |
FREEDGUY
Posted: 02 Aug 2020 at 6:39pm |
Thank you Grayray
DMiller
Joined: 14 Sep 2009 Location: Hermann, Mo Points: 35678 |
Posted: 02 Aug 2020 at 7:40pm |
Current pump systems carry roughly a quart of fuel within them back to the filtration and metering system, the solenoids as to from which tank they draw will send a volume of less than desired product out the nozzle first but should be less than or equal to a quart. Unless find a station with separate hoses for each grade are pretty well stuck with that quart.
Have watched people try to drain the hose after the pump stops and all the systems shut off, MAY get a tenth or two of a gallon off the nozzle and a little off the hose where requires pressure in the line to make the nozzle fully functional.
PaulB
Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5276 |
Thanks(1)
Posted: 02 Aug 2020 at 7:53pm |
Don't forget about all of the piping inside of the pump after the mixing valve. A couple of gallons for flush everything is always a good idea
Tbone95
Joined: 31 Aug 2012 Location: Michigan Points: 12418 |
Posted: 03 Aug 2020 at 6:43am |
"as to from which"
Boss Man
Joined: 03 Mar 2018 Location: Greenleaf, WI Points: 617 |
Posted: 03 Aug 2020 at 8:10pm |
I was told by a guy who works on pumps between a quart and quart and a half.
