Fuel pump problems on a 200 AC |
katahdingirl
Topic: Fuel pump problems on a 200 ACPosted: 19 Jun 2018 at 8:31am |
We have has this 200 AC for over a year and it runs and starts fine until now. Now it won't start at all. Won't fire. Hubbies worked on tractors all his life and is stumped. He knows the pump may have just went bad but just wanted to check and see if there might be another common problem before we take it all apart. It has fuel coming to the pump but not out of the pump.
injpumpEd
Joined: 13 Sep 2009 Location: Walnut IL Points: 5204 |
Posted: 19 Jun 2018 at 8:37am |
If it's been sitting for a while, especially if the fuel in it is old, the pump may be gummed up and will not pump fuel. Best fix is to have it properly serviced.
katahdingirl
Posted: 19 Jun 2018 at 9:10am |
Not been sitting....we were in the field with it when it just died.....we use it all the time.
grinder220
Joined: 11 Jan 2012 Location: Clinton Iowa Points: 2375 |
Posted: 19 Jun 2018 at 9:42am |
Might of just seized and sheared the key on the drive shaft. My 220 did that once. Take the little cover off the side of the pump (2 screws) and see if its turning when cranking the engine. There's 2 little timing marks there. One moves the other is stationary. Also try taking the return line AND FITTING off the top of the pump and try to start it. If it starts the flex ring inside is coming apart. Either way you'll need a rebuild.
Edited by grinder220 - 19 Jun 2018 at 9:42am |
Posted: 19 Jun 2018 at 11:42am |
Probably sheared the advance pin. The rear timing mark will not be seen if this is the case. The initial post says nothing about running in the field and dying.
katahdingirl
Posted: 19 Jun 2018 at 11:52am |
Sorry no it didn't.
Posted: 19 Jun 2018 at 12:17pm |
Accurate diagnosis has to have an accurate description of the problem. Running in the field and dropping dead is waaaaaay different than it just won't start.
calico190xt68
Joined: 12 Jan 2017 Location: Frankton, IN Points: 904 |
Posted: 19 Jun 2018 at 4:05pm |
Katahdingirl, you did the right thing by jumping on this forum and seeking help. These guys know a bunch about these tractors and they helped me out with my failed Injection Pump. I do believe I encountered the more common problem of the slow disintegration of the internals of the pump, which caused it to work sometimes and other times to not work. Should be easy for you to determine if the pump is advancing or not when the engine turns. Of course, diagnosing and installing and reinstalling the pump in the field sucks, so if you decide to pull it back to the barn, it can be tricky. Without the engine running, you have no steering, so you have to go slow. I believe you want to put the power director in neutral as well when pulling. I pulled mine about 400 yards extremely slow and had to adjust the tow strap as the tractor decided to go wherever it wanted. It was not recommended by members to pull it miles though to avoid transmission issues, even if you could do it safely. InjPumpEd rebuilt my pump and he does great work and turns it around fairly quickly, but it is still realistically a good 10 days. If you have something else like a broken shaft, then you may have a bigger problem. I am guessing you might as well deinstall the pump at this point unless you see upon further testing that it is turning as the engine cranks. I have a detailed post on this forum on the process I went through to take pump off and reinstall on my 190XT which is similar to the 200. Lining up your timing marks, is probably not possible by the description of the problem. You should score the position of the pump to the mounting plate to insure that you get it back where it was since it was running fine in that position. The biggest problem I had was folding back the seals on shaft on the reinstall which ran diesel fuel into the crankcase. If it happens, then you just have to start over. Sorry for your bad luck but please report back on your status. We always want to help new members!
calico190xt68
Posted: 19 Jun 2018 at 4:12pm |
One other thing, you might suggest to your hubby to inspect the sediment bowls and fuel lines. Mine had a bunch of gunk in them and the aperture was clogged on one of them. You can also blow out your lines with air while you have the pump off. It is possible that the plastic parts of your fuel injection pump can end up in your fuel lines and return lines too. Basically, this could be a good opportunity to make sure all is good with the fuel lines as well as the pump.
