Fuel Primer rebuild kit |
jeffgarc12 ![]() Bronze Level ![]() ![]() Joined: 01 May 2020 Location: Kansas Points: 43 |
![]() ![]() ![]() ![]() ![]() Posted: 24 Jan 2022 at 12:03pm |
I have a 1967 190xt that is leaking fuel on the fuel primer valve is there a good rebuild kit that would work for both the pump valve and the primer pump itself
ryan(IN) ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Bluffton,IN Points: 789 |
74063231 is the agco part number you local dealer may even stock one
ryan
1984 8070 FWA,1979 7060,1975 7040,1971 190,1960 D-17D,1957 D-14, 196? D-19G, 1975 5040,1971? 160,1994 R62 |
ac fleet ![]() Orange Level ![]() Joined: 12 Jan 2014 Location: Arrowsmith, ILL Points: 2337 |
AC dealer here refused to sell the kit and thought he would sell me the whole pump at $150.!--well it pizzed me off so I went next door to his store to napa and bought an electric pump for less than $50. and its still on there and works 100 times better than that silly hand thingy!
DSeries4 ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7515 |
I don't understand why you need a pump on there. The primer is only used when changing a fuel filter or opening up the system. Under normal conditions, how often would that be needed? My 190XT didn't even have a primer or electric pump on it when I bought it and the fuel system worked fine - almost the only thing on the tractor that did work! I pump a primer on the tractor when I restored it and it did its job to push fuel into the system.
