Fuel Gauge/Reminder Message ? |
FREEDGUY
Joined: 15 Apr 2017 Location: South West Mich Points: 5396 |
Topic: Fuel Gauge/Reminder Message ?Posted: 04 Jun 2021 at 5:31pm |
Is it just my '05 F250 that takes "forever" to raise the needle and de-activate the "chime" after filling up or are they all like this ? Sadly, I've let the buggy get to the point of the chime/message come on, but it takes a day for the needle to climb and the message to stop
thendrix
Joined: 04 Feb 2013 Location: Fairmount GA Points: 5175 |
Posted: 04 Jun 2021 at 5:42pm |
A day? Wow!! I would venture to say that's not normal.
FREEDGUY
Posted: 04 Jun 2021 at 5:51pm |
It's done this since I've owned it (5 years) and even the shop that replaced the fuel pump mentioned the issue AFTER the installation of a new pump
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 25247 |
Posted: 04 Jun 2021 at 6:09pm |
reprogram the *&^& computer to deactivate the *(&*&^& chime.....
Lars(wi)
Joined: 14 Sep 2009 Location: Permian Basin Points: 8402 |
Posted: 04 Jun 2021 at 6:34pm |
Definitely not normal. You should see the needle move while you are filling the tank, that is if you have the ignition on during fueling
FREEDGUY
Posted: 04 Jun 2021 at 6:50pm |
I've found that it takes about 5 "toggles" of the key switch to get the needle where it needs to be after fueling
. It's only a phenomenon when it get's low on fuel and the message appears on the dash, if caught a "little" sooner, no quirks . I thought maybe they all did this . I need to be more prudent on my fuel level . Thanks guys
Edited by FREEDGUY - 04 Jun 2021 at 6:51pm |
thendrix
Posted: 04 Jun 2021 at 7:34pm |
If you can find where the alarm is wired you might check for loose/bad connections. Just a thought
shameless dude
Posted: 05 Jun 2021 at 1:01am |
don't be a female...keep your tanks full! (Thad tolt me to say this)!
FREEDGUY
Posted: 05 Jun 2021 at 5:16pm |
LMAO
FREEDGUY
Posted: 05 Jun 2021 at 5:22pm |
Sadly, in this environment, that's not an option for me
. I'm NOT a retired /pension/ SSC earning citizen Not sure where to post my thoughts on the "PENSIONS" ??
Edited by FREEDGUY - 05 Jun 2021 at 5:26pm |
JW in MO
Joined: 16 Feb 2010 Location: South KC Area Points: 2696 |
Posted: 05 Jun 2021 at 5:55pm |
I noticed mine did that if I didn't shut the engine off while fueling, Ford, 350 diesel. Did it once when it was colder than Billy Hell then again to see if it would do it again. Didn't take a full day though, hour or so.
Joined: 11 Sep 2009 Location: illinois Points: 90801 |
Posted: 05 Jun 2021 at 11:00pm |
should clear on one cycle of the key.... not sure what a fuel signal has to do with Social Security ??
