Fuel bowl???? |
Post Reply |
Mikez
Orange Level Access Joined: 16 Jan 2013 Location: Usa Points: 8146 |
Posted: 27 Mar 2020 at 8:23am |
Hi everyone.
Is there a trick. Doing spring service on D17lV and changed the screen in the fuel bowl. With new gasket. Seems to leak a little. Don't remember ever haveing this issue in the past. Thought maybe even though gasket is new it still has been laying in bin for years and is dried out, needs to soften up a bit. Thanks |
DMiller
Orange Level Access Joined: 14 Sep 2009 Location: Hermann, Mo Points: 29484 |
As a old mechanic I used to soak fibrous gaskets in engine oil or ATF prior to installations, for Cork nothing and limit torque, for synthetics just make certain ABSOLUTELY clean.
plummerscarin
Orange Level Access Joined: 22 Jun 2015 Location: ia Points: 3120 |
There is a 170 here that the sediment bowl base is bent from overtightening.
BEK
Silver Level Joined: 05 Nov 2017 Location: Wilmington, NC Points: 216 |
I had the same problem. It may be time to replace the entire sediment bowl assembly. It will set you back about $30. Money well spent and for me no more leaking fuel.
john(MI)
Orange Level Joined: 12 Sep 2009 Location: SE MI Points: 9263 |
Tighten it up a little more. I've used pliers and have never broke a glass bowl.
Lon(MN)
Orange Level Joined: 11 Sep 2009 Location: Elk River,MN Points: 1905 |
Most leaks I find are on the shut off valve.
jiminnd
Orange Level Joined: 16 Sep 2009 Location: Rutland ND Points: 2207 |
With the bowl just snug, turn the bowl against the gasket a turn or so to seat it, will sometimes help and then tighten a little more,
WF owner
Orange Level Joined: 12 May 2013 Location: Bombay NY Points: 4388 |
Have you checked to make sure the metal side is good and clean? If it is, put it outside and let it leak for a while. When the gasket is saturated with gas, you will be able to hand tighten it a little and it should stop.
Mikez
Thanks guys. It stopped. Was dry today
Post Reply | |
