F-S A,E U and UC
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Topic: F-S A,E U and UC
    Posted: 19 Aug 2010 at 9:58pm
Flange mount left hand drive Amer. Bosh. Mag  Rebuilt
A front tank support
A,K-Crawler ,25-40 core heads W valves very good exhaust post
Engine to trans A tractor adaptor plate
A tractor Flywheel
A tractor over center hand clutch set up with clutch disc ( small trans shaft)
Rocker shaft's and push rods,A K,and 25-40
oil pumps A K ,and 25-40
Flange mount Gov. drive A tractor K crawler .
Base mount Gov drine Early K crawler and 25 -40
Rockers and push rods UM Engine
oil Pumps UM engine
Carb for UM engine .
Cont. U , UC engine timing gears,crank cam ,gov drive .sold as a set
UC Trans and rear w/ belt pulley
Clutch and PPA assembley U and UC
Gov. assembley UM engine
Call 717-451-6590, 8 AM to 9PM EASTERN TIME
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2010 at 10:01pm
A tractor front tank bracket
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2010 at 10:03pm
U , U-C Cont. Engine gears
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2010 at 10:05pm
Amer. Bosh . mag left hand A ,K
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2010 at 10:06pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 20 Aug 2010 at 5:36am
side panels U-40 P/U
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 20 Aug 2010 at 5:42am
U tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 20 Aug 2010 at 5:50am
A ,25-40,K crawler,E-60 P/U   .Has new oil cup .     I have NO air tubes from carb to air cleaner   for sale .
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 20 Aug 2010 at 6:01am
Fan - belt pulley  ,support assembley's Cont. engine turn free ,good bearing.I have 1 good fan ,will only sale with support and pulley assembley
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 20 Aug 2010 at 6:10am
I do have just a few othe A,25-40 ,and U ,UC parts . Drop me a PM with parts wanted ,I will let you know if I have it.  Thanks
If you do call or PM about a part that I do have and would want a shipping price and you do not get back with me with in 24 hour's ,it will not be marked sold until then.And could be sold. Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 20 Aug 2010 at 9:35am
Cast iron Steering wheel is SOLD !!  Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2010 at 7:31am
American Bosh. left hand drive mag ,A & K     Is  SOLD!!!!   Thanks Fred
