frozen oil???? |
shameless dude
Topic: frozen oil????Posted: 23 Jan 2020 at 3:09am |
went to use my canola oil the other night on the grill, and it was frozen solid! Darrel...you mixing water in them canola seeds up there? PffffT!
klinemar
Joined: 14 Sep 2009 Location: Michigan Points: 8074 |
Posted: 23 Jan 2020 at 6:26am |
Being from Nebraska Shameless cold weather should have given you the knowledge to bring your Canola oil inside! I can't poke you too bad as yesterday I had a Hay Customer show up who had contacted me ahead of time and I had forgot to plug the loader in! Took a battery charger and a lot of glow plugging but I got it started! As I get older I would forget my ass if it wasn't attached!
TimCNY
Joined: 15 Apr 2014 Location: Upstate NY Points: 1551 |
Posted: 23 Jan 2020 at 7:50am |
lol, coconut oil same deal... temps at or above 76*F liquid, below that solid, at some point ROCK solid.
I need more than 200 characters for my "signature." I'd love to see that changed to 250!
tadams(OH)
Joined: 17 Sep 2009 Location: Jeromesville, O Points: 11403 |
Posted: 23 Jan 2020 at 2:09pm |
shameless outdoor kitchen shut down weather too cold, come back in the spring
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42270 |
Posted: 23 Jan 2020 at 4:59pm |
Hmm - someone gave me 4 cans of Target brand - ATF fluid said Dextron type.
Broke a hydraulic line on snow plow and figured I would top off pump on truck with that oil - was below ZERO out and so was oil - went to pour it into hyd pump reservoir - was like putty and when pouring it was a long sagging string of red goo. so had to find other ATF and give that junk away |
shameless dude
Posted: 23 Jan 2020 at 10:20pm |
cooked out in the shack all day today, the canola oil was all thawed out this morning and didn't look any dif than usual, used some of it today.
HD6GTOM
Posted: 24 Jan 2020 at 3:49pm |
Coke my skid loader used dexron for hyd oil. It leaks on my cement. It has never been stringy. And it's cheap dexron too.
shameless dude
Posted: 24 Jan 2020 at 10:26pm |
my Gleaner combine used dextron for hyd fluid, never any leaks, never stringy, lots of snow blades use dextron, sounds like someone used some empty containers and put something else in them.
