Frost proof yard hydrant. |
BrianC
Joined: 16 Jun 2011 Location: New York Points: 1619 |
Topic: Frost proof yard hydrant.Posted: 04 Dec 2020 at 2:04pm |
I replaced my yard hydrant, was a Campbell, now is a Parts 2 O. The plunger in the Campbell was really stuck, so I decided to chuck the whole thing. Digging up the hole (3ft bury depth) was interesting and easy until I got to the gravel. Decided to test before back-filling the hole. The new hydrant is constantly leaking out the drain hole. The lever was very easy to shut closed, so I adjusted the set screw gripping spot on the pull rod. Now the handle's last 30 degrees needs moderate pressure to close it (5 pounds??, not a lot, I didn't want to mash the plunger). After letting it run and then shutting off, it still is "draining" from the drain hole down there 2 hours later. The instruction say 40 psi is the normal supply pressure, more will reduce lifetime on the components. I have 92 PSI water supply. What is going on? |
DiyDave
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 55276 |
Posted: 04 Dec 2020 at 6:01pm |
I can't remember the brand I like the most.(senior moment?) painted green, it s repairable, from the top, no digging.
When replacing hydrants, I spend the money, up front, I hates diggin in the cold, seems like that's when they fail... On edit, I found the name, its a baker! see link below. 92 PSI pressure sounds pretty damn high, I think that may be your main problem... |
mdm1
Joined: 12 Sep 2009 Location: Onalaska, WI Points: 2720 |
Posted: 04 Dec 2020 at 6:15pm |
As Dave said 92 psi is way high. Most wells are 40/60. Surprised you don't have other problems.
DougG
Posted: 04 Dec 2020 at 6:33pm |
Do you have a well or city water ? 92 lbs is way to much
BrianC
Posted: 04 Dec 2020 at 6:43pm |
I looked up the Baker hydrant, that sure is constructed differently than the ones I have. I could not find the PSI rating for it. The 92psi line is 1-1/2 galvanized pipe, runs out 240 feet to garden. It is tapped before the water pressure regulator for the home. Home was converted from well system to municipal water sometime in the '90's. I bet the old shallow well system could only hit about 45psi. Thing is I like the high pressure. I can water in bigger circles, spray higher up the apple trees and such. Sounds like more plumbing or convert to dumb faucet and drain for winter. I use it for gardening only.
plummerscarin
Posted: 04 Dec 2020 at 7:35pm |
92 is very high. From a code perspective, if over 80 then a pressure reducing valve would required. Some pressure to close the handle would be normal in my opinion. Also be sure there is no dirt or other objects preventing proper seal when off and there is no damage to the seat or washer.
HD6GTOM
Posted: 04 Dec 2020 at 10:56pm |
We've been using Iowa hydrants since the 1960's. I I cannot remember a leaker. We have to put them down 6' here.
Kansas99
Joined: 26 Feb 2015 Location: W Kansas Points: 4868 |
Posted: 05 Dec 2020 at 7:04am |
Interesting, hadn't heard of them but according to their site these are rated up to 125psi.
Sounds like a pretty good hydrant. |
DiyDave
Posted: 05 Dec 2020 at 6:02pm |
Last one I bought a coupla years ago was around $130, IIRR, for a 7' (total length). Of course local prices will vary. I bought it at the local Drillers Service store, check them out, they may have a location, near Brian's, or you, K99...
FREEDGUY
Joined: 15 Apr 2017 Location: South West Mich Points: 5396 |
Posted: 05 Dec 2020 at 6:20pm |
Are you certain that whatever gauge that reads 92 PSI is accurate ?? That seem excessive from a municipality unless your first in line from their pumping station (in between filling the water tower)
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42266 |
Posted: 07 Dec 2020 at 3:06pm |
When installing the hydrants for farm use - I used a 5 gallon plastic bucket to set hydrant into , then made connections - allowed a void around the valve to allow drainage and kept the hole from getting plugged or sand getting into valve .
I would expect the seat in your hydrant valve is bad as it should seal without leakage at ANY pressure if it is working . |
FREEDGUY
Posted: 07 Dec 2020 at 5:07pm |
Have you DONE the "repair from the top" fix ?? I just CAN NOT imagine lining thigs up 4' down in murky/muddy waters ??
Joined: 11 Sep 2009 Location: illinois Points: 90808 |
Posted: 07 Dec 2020 at 6:10pm |
Read "L" on the Baker unit..........
Hubert (Ga)engine7
Joined: 12 Sep 2009 Location: Jackson Cnty,GA Points: 6610 |
Posted: 07 Dec 2020 at 6:31pm |
When I was working with the fire department I ran across a lot of hydrants that checked out well above 100 psi, had a few that pushed 150 psi. Some places we could just let the pumper idle and get more than enough pressure on the lines.
FREEDGUY
Posted: 07 Dec 2020 at 6:38pm |
Fire hydrants are one thing, and I would hope they have massive PSI, residential PSI is a different animal
Kansas99
Posted: 07 Dec 2020 at 6:56pm |
Same water main as residential. ![]() My younger brother is the very last farm on rural water and there is a water pressure regulator in the basement depending the day pressure will easily excede 100psi coming in. He's 20 miles from the pump station and 9 miles from the booster tower. |
Posted: 07 Dec 2020 at 7:10pm |
A lot of the "pressure" depends on where you are located ( vertically) from the water tower.... every 2 ft of height is about 1 psi ... you live in the valley you got pressure.. You live on top of the mountain, you got not much....
and yes. BOOSTER stations are used to push if your going longer distances thru the country / rural areas.
GARY(OH/IN)
Joined: 19 May 2010 Location: Findlay,Ohio Points: 917 |
Posted: 07 Dec 2020 at 10:01pm |
I have read somewhere and also heard on Gary Sullivan's home repair show out of Cincinnati that municipal water systems are only required to maintain at least a water pressure of 20 psi. Federal EPA law I believe. I own a mobile home park with a well and recall receiving paperwork from the EPA wanting me to notify them if the pressure ever fell below 20 psi. Any shut downs for maintenance are posted in a daily log book. I run at 30-50 psi and believe 90+ psi would create leaks bigtime. Scares me!
naylorbros
Joined: 14 Sep 2009 Location: West Jordan, UT Points: 104 |
Posted: 08 Dec 2020 at 6:53am |
The pressure coming into my school before the pressure regulator runs usually between 125 and 130. At home we have several of the Woodford Y34 IOWA hydrants. I would no buy anything else
plummerscarin
Posted: 08 Dec 2020 at 6:54am |
20psi is minimum requirement in any plumbing code. Things go sideways when adding in elevation and distance. The city I work in has fluctuations to both extremes. Add booster pumps to some homes then pressure regulators to others.
