FRONT WEIGHT
SIMPLICITY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SIMPLICITY Quote  Post ReplyReply Direct Link To This Post Topic: FRONT WEIGHT
    Posted: 31 May 2023 at 7:09pm
DOES ANY ONE KNOW IF THE BIG SQ,CASTED U SHAPE WEIGHT WITH 2 BOLT HOLES WILL FIT THE FRONT OF A 185 ? ALSO IS THERE A SPECIFIC NAME FOT THAT WEIGHT?
Darb210 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Darb210 Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2023 at 7:25pm
if it is the one im thinking of then yes it will.  starter weight or chin weight is what they are normally called.  can stack smaller slabs outward on also
Post Options Post Options   Thanks (0) Thanks(0)   Quote SIMPLICITY Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2023 at 7:27pm
YES I THINK YOU ARE RIGHT
Unit3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2023 at 9:04am
How many tractors did the "U" shaped or starter weight work on?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2023 at 9:09am
170-early 175-180-185-190-190XT-200 and I think the 210-220 also used the same weight even tho the side frames were wider.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2023 at 1:34pm
yes they narrowed the front hsg on 220 to accept the starter wt
This page was generated in 0.250 seconds.
