Front tire size
JCSinPITTS,PA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JCSinPITTS,PA Quote  Post ReplyReply Direct Link To This Post Topic: Front tire size
    Posted: 28 Jul 2023 at 6:35am
another question, Please!   it appears some front wheels are 15 inch and some are 16 inch on the tractors i have, whats up with that?
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jul 2023 at 7:58am
It depends on the size of the tractor... B, C were 15 inch... Larger D series are 16 inch.
That being said... many rims have been changed over the last 60 years.
 What do you have ?
Edited by steve(ill) - 28 Jul 2023 at 8:05am
rrhead(SD) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rrhead(SD) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jul 2023 at 4:15pm
My D-19 has 15 inch tires on it. The rim measures 16 inches across. All the references I have seen, says it should be 16 inch tires.
2 WDs,WD45,D-14,D-17,D-19D,180,7020,6080FWA,6080 2wd, 6080 2wd(cab),8050FWA,8550,4W-305,Massey 8250. Gleaner L3, R62 &R65 Agco-Allis 1616H & 1920H, AC 720, Terra-Tiger
Jim.ME View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim.ME Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jul 2023 at 5:51pm
A 15inch tire isn't going to like seating up on a 16 inch rim.  Where are you measuring the rim?  The rim diameter is actually measured across the inside of the rim at the black arrow where the bead seats,  not across the outer lip of the rim.
Post Options Post Options   Thanks (0) Thanks(0)   Quote rrhead(SD) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jul 2023 at 6:09pm
That does measure 15 inches. Wasn't sure where to measure. That must mean they have been changed at sometime. Thank you very much for the info. rrhead(SD).
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2023 at 5:29am
The rim size is usually stamped into the rim.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2023 at 7:16am
Many 200's and later 185's had a 6-bolt  9.5L x 15 front wheel. That might be what you have with a 7.5 tire.
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2023 at 9:05am
I have 7.5L 15's on my Wide Front 45. Electric wheel rims off some sort of jd.
Post Options Post Options   Thanks (0) Thanks(0)   Quote rrhead(SD) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2023 at 11:08am
Dr. that is good to know. I need to replace the tires on the front and I think 9.5 would look good on the front of a D-19D with 18.4 x 34 on the rear. rrhead(SD)
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2023 at 11:09pm
i am going to put 9.5 x 15 four ribs on my d17d they will be about the same hight as as the 6.50x16s  i think 1 inch higher  but i have 16.9 s on the rear  so it will still sit level
