Front Rims: |
Codger ![]() Orange Level ![]() ![]() Joined: 23 Dec 2020 Location: Utopia Points: 2412 |
![]() ![]() ![]() ![]() ![]() Posted: 08 Jun 2025 at 10:16pm |
I need to upsize the front rims on my tractor. Originals are 4.5" wide and thinking I need 6.0" width. I changed front tires from 6.50", to 7.50" and used the original rims.
My original rims have a much heavier center to them than the replacements I've seen online. Also six welded webs to the rim opposed to four I've seen, and shown here: I don't have a loader and not planning to install one, but do carry three suitcase weights always on the front and mow ditches, etc. I went with Firestone four rib, eight ply tires in F-2 pattern in memory serves and with the way they are "rounded" through the tread really cut into the grass upon turning. I'd like to flatten the tires out as they should be. Anybody have recommendations to call for obtaining good quality rims? I'm not opposed to sending these to a place in California I've used in the past to make what I'm wanting; if that is the only option. They would reutilize the original centers installing with the offset needed. My old Clark TLB has bent agriculture rims on the steer axle and someone prior to my ownership installed those so I've seen the result of too light duty of rim for the application.
That's All Folks!
steve(ill) ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: illinois Points: 86454 |
most of the 6x16x6 rims are 2800# rated..... they alsos make a 3500# rim.. actually cheaper ??
TedN ![]() Bronze Level ![]() Joined: 30 Apr 2025 Location: Central WA Points: 34 |
I just recently went the other direction - had 16 x 8 wheels with 7.50-16 tires on my 190XT, I bought a pair of 16 x 6 wheels (3500#) and the tires look much better on the proper wheel. The fresh paint looks a little nicer too. If the outfit in California that you dealt with before was Stockton Wheel I heard the building burned down and they didn't rebuild. Our current supervisor at work was the store manager at Stockton Les Schwab (tire store) less than a year ago, and Stockton Wheel came up in a discussion at work last week.
Gary Burnett ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: Virginia Points: 3044 |
I have used New Holland round baler rims with no problem on the front of a couple tractors,they are a heavy rim.The one set is on the front of an AC 185 that I had a loader on for awhile and the other is an Oliver 1365 with a loader I use to mover round bales.
WF owner ![]() Orange Level ![]() Joined: 12 May 2013 Location: Bombay NY Points: 4936 |
Hey Wheel ( DROP CENTER WHEELS ) has 16" x 6" - 3500 lb. rims for $95.
I do believe it was Stockton Wheel but haven't been in the files to verify. Had them install 7.5X15 larger rims onto my 4.0" bolt circle Chrysler "A" body wheels for my Barracuda.
My front rims have a very deep negative offset to them. Almost 5.0" with a tape measure and seems a bit of an oddity. Inside sidewall of tires clear top of king pins by about 1/2" on each side. There was more clearance with the original 6.50X16 three rib tires, but not a lot. I'll grab photos later today and post. Thanks for the help.
That's All Folks!
560Dennis ![]() Bronze Level ![]() Joined: 30 Apr 2011 Location: NE OHIO Points: 122 |
How many lug is that 4.5 and hud diameter . I m not farmilar with the application cuase im looking for 2plow wheels 4.5 wide 16 .
To share I get new rims from Aaron Wenger in New Holland ,Pa. Got five acres of rims , Called and leave message ,rare they pick up. If you go there you will see why 'probably loading two or three trucks. Biggest inventory east of the Mississippi.They have it
These are a 6X6 bolt circle pattern. I don't know the hub diameter but will probably remove a wheel this morning and measure parameters.
That's All Folks!
8070nc ![]() Orange Level Access ![]() Joined: 21 Mar 2019 Location: North Carolina Points: 572 |
What is wenger phine number please
1984 80780
1957 D14 DES 300 with 25000 engine 616 tractor |
Aaron Wenger Systems
im4racin ![]() Orange Level ![]() Joined: 12 Jun 2017 Location: Garrison ND Points: 1028 |
Thanks
1984 80780
orangeman ![]() Orange Level ![]() Joined: 12 Sep 2009 Points: 1837 |
Codger: I went through a similar exercise with our AC 621 Forklift. When it was purchased new it had 6.50 x 16 " rims on it with 7.50 x 16" tires mounted on them ~ same rim and tire setup as an D17. I didn't care for the "cutting in" on my yard area so solved it with a 10" x 16" rim blank and had the centers machined to fit the blank. The blank and center was supplied by M.E. Miller Tire Company of Wauseon, Ohio - see link here: -https://www.millertire.com/
I mounted 11L x 16" Goodyear Laborer 12 ply on it and never looked back! While my situation was different from yours - you get the idea!? HTH's ~ Orangeman
I went back and looked, my front wheels were through Quality Farm Supply, $93 each delivered. I"m happy with them, but mostly just pull a baler so I don't require much.
