Front hydraulic pump
OldFarmer@6883 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote OldFarmer@6883 Quote  Post ReplyReply Direct Link To This Post Topic: Front hydraulic pump
    Posted: 26 Apr 2024 at 5:33pm
I noticed a post about a front hydraulic pump on a D17. I have D19 that hasn't had hydraulics for at least 20 years because the belly pump went out and I didn't want to tie up the pto. How do expensive, how do you do it, does it have enough gpm to run a loader, etc.?
Thanks for the info.
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2024 at 6:44pm
I had a D19 with a factory front pump so I'd guess everything would be in the parts book.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2024 at 6:58pm
The factory D-19 front pump was only about 5 GPM and you want something that is 10 or 12 GPM at full throttle. NONE of those D-19 parts are available any more. What you can do is source a front pump to an A-C all hydraulic loader, which those parts are available and the pump is 10-12 GPM. A & W tractor may have what you need.
