Front End Loader |
fixer1958
Topic: Front End LoaderPosted: 28 Apr 2010 at 8:15pm |
Would have to see a pic because I am putting a #170 on mine and the main frame on the tractor fit like a glove. Looks decent also. The part that hangs off the axle is questionable, but that can be changed.
Brian G. NY
Posted: 28 Apr 2010 at 5:56pm |
Well, I've come to the conclusion that the loader arms are New Idea and the frame that bolts to the tractor is A-C; I had that reversed in my original post. This should be a good match for the D-17 I picked up this past winter.
Altho the seller "threw in" a New Idea loader that he had used on the D-17, I believe
this one is built much more ruggedly.
I will attempt to send pictures later.
Chris/CT
Joined: 11 Sep 2009 Location: Niantic, Ct Points: 1939 |
Posted: 28 Apr 2010 at 2:22pm |
Model 170 looks to be built by AC for the D-17 tractor. Around 1968+/_.Model and serial number on RH Frame member "Model 170-XXXX. Post pictures of frame for ID?
Brian G. NY
Posted: 28 Apr 2010 at 1:32pm |
Coupla questions.
#1 Was there an A-C Model 170 front end loader?
#2 If so, was it built by New Idea?
I have a loader that came on a WD-45 I bought several years ago.
It seems a little big for a WD-45 and it was "cobbed" to fit it.
The main lift arms have a tag that has been painted over several times
which says Allis-Chalmers with what appears to be model 170.
The frame which bolts to the tractor has a plate that says New Idea
Model 506, Lot #ML-113, Ser. # 681.
Are these supposed to go together or is it more likely that someone combined parts from the two to make one?
Thanks
