Front End Loader
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Topic: Front End Loader
    Posted: 28 Apr 2010 at 1:32pm
Coupla questions.
#1 Was there an A-C  Model 170 front end loader?
#2 If so, was it built by New Idea?
I have a loader that came on a WD-45 I bought several years ago.
It seems a little big for a WD-45 and it was "cobbed" to fit it.
The main lift arms have a tag that has been painted over several times
which says Allis-Chalmers with what appears to be model 170.
The frame which bolts to the tractor has a plate that says New Idea
Model 506, Lot #ML-113, Ser. # 681.
Are these supposed to go together or is it more likely that someone combined parts from the two to make one?
Thanks
Chris/CT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2010 at 2:22pm
Model 170 looks to be built by AC for the D-17 tractor. Around 1968+/_.Model and serial number on RH Frame member "Model 170-XXXX. Post pictures of frame for ID?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2010 at 5:56pm
Well, I've come to the conclusion that the loader  arms are New Idea and the frame that bolts to the tractor is A-C;  I had that reversed in my original post. This should be a good match for the D-17 I picked up this past winter.
Altho the seller "threw in" a New Idea loader that he had used on the D-17, I believe
this one is built much more ruggedly.
I will attempt to send pictures later.
fixer1958 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fixer1958 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2010 at 8:15pm
Would have to see a pic because I am putting a #170 on mine and the main frame on the tractor fit like a glove. Looks decent also. The part that hangs off the axle is questionable, but that can be changed.
