Front Cult. on wide front
Kraig (WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kraig (WI) Quote  Post ReplyReply Direct Link To This Post Topic: Front Cult. on wide front
    Posted: 10 Jun 2010 at 3:49pm
Will two row front cultivators go on a WD wide front? I know I couldn't drive in and out of them. They would have to be taken apart to mount them, and taken apart to take them off. But would there be any other problems with doing this?
Kraig
7010,D17D,WD45,WD,WC,WC,B,
Gleaner K,60,66,72
wf32 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wf32 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2010 at 4:00pm
Yes it will we used to have one on a WD  also had a 4 row on aWD45 both had wide fronts
Phil
Larry Miller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry Miller Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2010 at 4:45pm
You don't have to take them apart - they hinge from outer end of the front bar and only have to bolt or unbolt them to the frame. Not light or easy but can be done.
I used to be young and stupid, now I am not young anymore.
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2010 at 8:19pm
I have a two row on a WD45 with a wide front and get along fine with it. Don
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jun 2010 at 11:08pm
My dad used to fight a 4 row to get it on our wide front WD45D with a wood post....inside rows need the same clearance as a two row when mounting, but twice as much iron to muscle around.  To top that off, he took it off in a quanset barn against the outer wall....then horsed it back together so he could back the 4 row lister in between the row openings of the cultivator.
ALLIS EXPRESS!
This year:
